Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Runva 9,500 Comp winch or 12,000lb Standard?
    Mar 2013
    NE Melbourne
    I have a Runva 9500 Q Comp winch in a standard Nissan winch bar and it just fits. Check dimensions on Runva web site as I think the 9500 is longer than the 12000. It has bigger motor 8.6hp. They are same winch but different motor and gearing.
  2. #12
    Expert AJTich's Avatar
    Oct 2013
    Andrews Farm
    Quote Originally Posted by Rock Trol View Post
    Thanks. If someone has fitted the 12000 then will definitely know. Otherwise will just fit it and see what needs rejigging if any...
    AJTich
    2004 GUIII, white ST, 3.0L manual wagon, NADS,EGT/Boost,Water Temp/Oil Press gauges, drawers, UHF, stubby cooler on the 4WD selector...
    "I don't get bogged, I have unplanned 4WD training activities..."
  3. #13
    Mego's Patrol has an ARB deluxe winch bar fitted
    MEGOMONSTER (28th July 2015)
  5. #14
    Oct 2013
    Andrews Farm
    Thanks dude. I saw that. .after I posted. Sorry.
    AJTich
  6. #15
    Western suburbs of Melbourne
    11 Post(s)
  7. The Following User Says Thank You to MEGOMONSTER For This Useful Post:
    AJTich (28th July 2015)
  8. #16
    Mar 2013
    NE Melbourne
    With the Nissan steel bar the winch needs to be flipped upside down so that the motor is on the passenger side and the cable rolls off the top of the drum instead of the bottom as in MEGOMONSTER's pics.
    The Nissan bar also only has a rating of 9000 pounds. The guys who sold/installed my winch wouldn't put anything bigger in mine for liability reasons even though they sold the 11000 & 12000 pound Runva's for the same price. Their reasoning being that if they put a 12000 pound winch in the bar and I really got stuck the power of the winch might destroy the bar or rip it off. My 9500 pound winch would stall at around the correct load and not damage the bar (in theory). If I need more power I can rig up a pulley and double power to 19000 pounds and spread the load over the bar and one of the recovery points. It would also winch at the same speed as the 12000 pound winch as it is normally twice as fast.
    In the picture below you can just make out the gearbox lever on the left hand side. The gearbox needed rotating as well so it would fit.
  9. #17
    Oct 2013
    Andrews Farm
    Yep, flipping etc is all good. Maybe best aa you said to choose closer to 9000..
    AJTich
