Page 581 of 1670 FirstFirst ... 579580581582583 ... LastLast
Results 5,801 to 5,810 of 16693
  1. #5801
    Thomastown, Melbourne
    6 Post(s)
    Margherita just resigned..... hooray!!!
  2. The Following 5 Users Say Thank You to Bloodyaussie For This Useful Post:
    Clunk (3rd July 2015), mudnut (3rd July 2015), Stropp (3rd July 2015), Winnie (3rd July 2015), Woof (5th July 2015)
  3. #5802
    Hooray, congrats! Were they surprised?
  4. #5803
    178 Post(s)
    Feeling a bit pleased with myself. It’s been a while since I did any woodwork & have spent much of the past week knocking up a new workbench for the new shed, having decided that step one of fitting out the shed needs to be the establishment of the workshop section. Walking between old & new sheds multiple times to do just about anything because tools/machinery are spread between the two was wearing very thin. So first a new workbench, then some power & lights for the workshop are the current agenda.
    This was my ‘detailed’ plan for the bench on a piece of scrap paper. Mostly in my head following the usual ‘Cuppa’s making it up as you go along’ model.
    And this was the outcome
    6 metres long. Frame & legs all 90 x 45 ‘merchant grade’ pine studs - except for leg where vice will fit - a section of 100 x 100 verandah post I kept when replacing one which was rotted out at both ends. Bench tops are yellow tongue flooring with additional crossbracing underneath. Wall backboard & shelf is 12mm ply attached to 90 x 45 timber.
    And this is my new favourite tool. (The whole thing is only screwed together (used around 700 screws!) to allow for dismantling should I ever want to move it elsewhere. Solid as!)
  5. The Following 12 Users Say Thank You to Cuppa For This Useful Post:
    4bye4 (5th July 2015), Bob (5th July 2015), cgm (5th July 2015), clawrence (6th July 2015), Clunk (5th July 2015), graeme1969 (5th July 2015), jack (6th July 2015), lhurley (5th July 2015), my third 256 (6th July 2015), threedogs (5th July 2015), TPC (5th July 2015), Woof (5th July 2015)
  6. #5804
    finished cleaning off the snatch strap in the washing machine....... tis very clean now
  7. The Following User Says Thank You to Clunk For This Useful Post:
  8. #5805
    @ cuppa you having lock up doors for your electrical tools
  9. #5806
    178 Post(s)
    Possibly TD. Will decide once higher budgetary priorities are taken care of.
    Having been accustomed to getting timber for next to nothing back on the farm I’m still in a state of shock over the cost of timber. Believe it or not there is over $600 of materials in that bench!
  10. #5807
    Patrol Freak lhurley's Avatar
    Oct 2011
    Brisbane. Manly West.
    @cuppa
    how do you find the flooring board as a bench top? i need to make a new work bench and im undecided what i want to make the top out of
    1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me )
  11. #5808
    178 Post(s)
    Quote Originally Posted by lhurley View Post
    @cuppa
    Too early to tell as I only finished building it today & haven’t used it for anything more than a ’shelf’ yet.
    It’s a lot heavier than ply & quite rigid on it’s own, but I added additional cross members underneath it which I screwed the top to, to make it as rigid & ‘bounce free’ as I could. It’s also perfectly flat & warp free. I think it will work well. The top surface has some sort of wax impregnation to give it a degree of waterproofing (designed to sit out in the elements for up to 3 months whilst a house is being built. It feels like quite a hard surface which I think will be quite durable, certainly a lot more so than ordinary chipboard. I plan to use it as is & think it will cope well but if I find after a while that the surface does deteriorate it would be easy enough to cover it.
    Cost wise - if money were no object I’d probably choose 150mm thick seasoned hardwood strips laminated together & covered with metal or laminex sheet but I didn’t want to take out a mortgage! The yellow tongue was $42 for sheets 3600 x 900 x 19mm - 2 per bench with enough left over to make a couple of shelves elsewhere & a couple of doors for the ‘cupboard’ I’ve built to house the water pump. You can get the same flooring in thicker section too - Red tongue =22mm & Blue Tongue =25mm but it would be *very* heavy to work with. We (wife & I) ripped the length of our 19mm sheets on my old Triton saw bench & I’m really not sure we’d have managed it any heavier.
  12. The Following User Says Thank You to Cuppa For This Useful Post:
    lhurley (6th July 2015)
  13. #5809
    Advanced morton2478's Avatar
    Mar 2015
    Catch can, dawes and needle valve on there way many thanks mudski
  14. The Following User Says Thank You to morton2478 For This Useful Post:
    Hodge (6th July 2015)
  15. #5810
    @cuppa
    I've made a few work benches over the years the best one was 50 x 50 x 6 angle iron. It had a lower lockable section a big under top drawer
    the top I inverted the angle and filled with 25mm timber x 2 then clamped and welded a sheet of 3mm steel on top, for electrical work
    a piece of rubber matting up one end worked a treat. Wish I had it now, The one I made for home is made from 50 x 50 x2 rhs with 3mm top
    solid as.
