Page 511 of 1057 FirstFirst ... 509510511512513 ... LastLast
Results 5,101 to 5,110 of 10564
  1. #5101
    Do they except cards that big?
    That particular one Grunter bought will........
  2. The Following User Says Thank You to Clunk For This Useful Post:
    threedogs (14th June 2015)
  3. #5102
    Patrol Guru Covo71's Avatar
    Dec 2012
    Coffs Harbour
    I had the CRA bar put in so I put the cargo barrier and draws in. Attachment 58886
  4. The Following User Says Thank You to Covo71 For This Useful Post:
    Clunk (14th June 2015)
  5. #5103
    WA Wheatbelt
    23 Post(s)
    You shouldn't need too my dear Bitumen Bunny
    It's telling me to "Please check your SD card".
    Don't know what's wrong with it. My email is playing up and I'm waiting for a response from the people I brought it off. It wasn't fitted when I bought it. All I did was insert the SD card.
  6. #5104
    Do you have an micro SD card adapter and do you have an sd card slot in your computer? If so, then pop it into your pc and see if it recognises it.
  7. #5105
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    also check that the unit WILL take 64G card
    I have a camera that wont take over 24G and and another that wont even take a HD card
  8. #5106
    Mine takes a 4gb card and more than enough fo a trip up to the Murray [2hrs]
  9. #5107
    Quote Originally Posted by Bigcol View Post
    says so in the specs
    Model DR650GW-2CH Full HD
    Channel 2 Channels (Dual Camera)
    Color/ Size / Weight Front BLACK - (Length) 118.5mm x (Diameter) 36mm / 120g
    Rear BLACK - (Length) 67.4mm x (Diameter) - 27.6mm / 30g
    Storage microSD Card (16GB/32GB/64GB) Supported. (32GB INCLUDED)
    Camera Front - SONY EXMOR CMOS Sensor (2.4M pixels)
    Rear - CMOS Sensor (1M pixels)
    Viewable Angle Front - Diagonal: 129Deg / Horizontal: 103Deg / Vertical: 77Deg
    Rear - Diagonal: 129Deg / Horizontal: 103Deg / Verical: 57Deg
    Resolution Frames/Sec Front - Full High Definition 1080P @ 30fps
    Rear - High Definition 720P @ 30fps
    Video Format MP4
    GPS and Wifi YES - Built In
    Accelerometer YES - Built In 3-axis G-sensor
    LED Indicators YES - Built In
    Battery Built In Capacitor
    Voltage 12/24 Volts DC
    Power Consumption Max 4.8W
    Operating Temperature -20 - 60 degrees C
    Software Support Blackvue Viewer for PC or MAC. Blackvue APP for Android and iPhone
    Video Out NO
    Whats In The Box Blackvue DR650GW unit (Front + Rear Cameras)
    User Manual
    Power Cable
    32GB MicroSD Card with Blackvue Viewer Application
    Adhesive Tapes for mounting
    MicroSD Reader
    Coaxial Cables
  10. #5108
    GGRRrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr rrrrrrrrrrrrrrrrrrrrrrrrr
    One guy has gone to look at a clumysdoor, one son is here and the other is heavens knows where
    again GGRRrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr rrrrrrrrrrrrr
  11. #5109
    Expert AJTich's Avatar
    Oct 2013
    Andrews Farm
    Video Format MP4
    Video Out NO
    User Manual
    Power Cable
    MicroSD Reader
    Coaxial Cables
    I've got one too and same issue. Was a bas#/#/# as I put the 64 in and drove to find it didn't recognise that card. Grrrrr.
    AJTich
    2004 GUIII, white ST, 3.0L manual wagon, NADS,EGT/Boost,Water Temp/Oil Press gauges, drawers, UHF, stubby cooler on the 4WD selector...
    "I don't get bogged, I have unplanned 4WD training activities..."
  12. #5110
    Ran a new 16mm2 welders flex from the alternator to the cranking battery with a circuit breaker in line.
    Now I won't blow the main 65A fuse when winching under load.
  13. The Following User Says Thank You to Winnie For This Useful Post:
    threedogs (15th June 2015)
