Results 1 to 10 of 13
Thread: Air Compressors
    Jun 2015
    Adelaide
    Air Compressors
    I have been looking at a few air compressors and note they rate them as 40lit/min or 150/lit a min etc and wondered if members could tell me how this converts in regards to inflation time. If I have a tyre at say 15psi how long would it take to pump up with say the 40lit/min unit?
  3. The Following User Says Thank You to threedogs For This Useful Post:
    Hallett505 (7th June 2015)
    Patrol Guru paulyg's Avatar
    Ballarat
    Those numbers are the amount of air the compressor can deliver.
    The higher the number the faster it will inflate a tyre.
    2010 TB4.8, 5 speed auto TI Wagon, Beaudesert ceramic coated Extractors and 2 1/2 inch exhaust, 3inch lift, BP-51 shocks, Black hawk radius arms and drop boxes, Road Runner Offroad billet alloy draglink, Boss air bags, 295/70/17 KM3s, Redarc Gauges, GME XRS UHF, Autometre fuel gauge, Alpine head unit with offroad maps, Carbon winch, Opposite lock bull bar, Light Force Strikers, Safari Snorkel, Duel long range tanks, work in progress.
    Quote Originally Posted by Hallett505 View Post
    A good pump should take about 3-5mins to re inflate a tyre
  6. The Following User Says Thank You to threedogs For This Useful Post:
    Mar 2013
    NE Melbourne
    I think now days you can get a 70 lpm plus pump quite cheaply. No reason to go lower. The 160 lpm pumps are very fast but are bulky and heavy compared to the smaller pumps.
    Then there is the price and quality issue. The good brands are ARB, Bushranger, Thomas etc. But they are pricey. I have a couple of cheapies (85 & 160 lpm) that have worked well over the last 4 years. Still going strong but if I had to buy another I would get a better name brand.
  8. The Following User Says Thank You to Rock Trol For This Useful Post:
  9. #6
    Expert Patrol'n's Avatar
    Oct 2014
    WA
    The advice given to me when I started 4 wheeling was get the best compressor you can afford, there is a useful article by 4wd action magazine, if you google search air compressor review it's about the first result. The review gives times to air up by different models.
    I tried a cheap unit first, and it worked ok, I don't remember the brand, the only downsides were that it got really hot and after a while started to leak oil around the cylinder.
    Based on the 4wd action review I looked closely at the Dr Air pro flow 150lt unit. Looked good and cost just over $200 on special at Auto Pro so I would have local support if anything went wrong. IMHO it is a good unit. I have aired up a lot of tyres with it, mine, mates and other peoples, even a motor home that had gone down a 4wd track and got stuck in soft sand.
    93 GQ wagon, RB30, extractors, 2 inch tough dog lift, 5 spd, A/T KO2 32's, steel winch bar, rated recovery points, red arc dual battery set up, rhino roof racks, UHF etc etc. Slow and steady might not win the race but it gets me there eventually...
  10. #7
    177 Post(s)
    The other factor as well as litres per minute is ‘duty cycle’. Some might be capable of 150 litres per minute, but with a low duty cycle requiring them to be switched off after each tyre & a waiting period before the next is inflated. Most have a duty cycle which is better than that, but something to be aware of if you expect to be inflating yours & your mate’s tyres or want to be able to use an air gun or other air tools.
    I have the Boss PX7 with an air tank, with pressure cut off set at 120psi. I bought it on the recommendation of several other folk who have them. It may be overkill for my purposes (although I do find an air gun very useful) but I am confident it won’t let me down in some remote area. A very well travelled mate who runs 20” tyres on his OKA has been using his for well over a decade now, without any maintenance other than occasional cleaning of the air filter.
    The time to inflate from 15psi to 40 psi would be pretty much the same as the compressor on a servo forecourt.
    https://www.youtube.com/watch?v=n23wJ5873Wc
  11. The Following User Says Thank You to Cuppa For This Useful Post:
  12. #8
    I have the same as Cuppa but now I think there are better smaller more efficient pumps out there.
    If you can combine it with a air tank like I did on my other 4x4 and you'll be using air tools such as rattle guns.
    The best option is to run Endless air, they tell me it takes about a day to fit but you have huge air at the touch of a button.
    Air tanks are the way to go IMHO
    There is a better pump than the boss PX7 or the Big Black pump as I know it,
    It runs in an oil bath and has an air tank attached around the $800 mark down my way
    in Altona I think, an engineering mob sells them, Nearly up there with Endless Air
    Also be wary if it has a thermal cut out for over heating , cause if you mount it under your bonnet
    it may not work till it cools down
  13. The Following User Says Thank You to threedogs For This Useful Post:
  14. #9
    Jun 2015
    Adelaide
    Thanks for the advice everyone, now I have a much better idea what to look for!
  15. #10
    Mar 2014
    Holsworthy, NSW
    Quote Originally Posted by Patrol'n View Post
    I also have the Dr Air Pro FLow 150lt unit - great compressor so far gets a little hot but not too bad.
  16. The Following User Says Thank You to Xtreme For This Useful Post:
    Hallett505 (11th June 2015)
