Results 1 to 8 of 8
Thread: GQ front hubs are getting very hot
    Beginner mudbug's Avatar
    Sep 2013
    Hi people hope some one can help me out i have had my swivel hub bearings and one set of wheel bearings replaced the other was cleaned and re greased i went off roading for a day ( rocky terrain no water or mud ) when i unlocked the hubs i noticed they were ouch hot I'm not sure if i did any damage , there is no grinding or clunking it drives great now my hubs are getting really hot under normal 2wd on roads i have looked at one set of wheel bearings cleaned them and put it all back together but and still they both get hot , I'm not sure where to look now any one got some hints
    cheers
    mudbug
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    Could be your wheel bearings are too tight. You can Back them off a little and check for play
    Edit: I think the torque settings are like 3-5nm so they don't need to be very tight
    Lucus30's 1999 GU ST TB45E
  3. The Following User Says Thank You to lucus30 For This Useful Post:
    mudbug (5th April 2015)
    Sep 2013
    not sure of what torque settings i had but i did check for play in the hub before i checked the bearings ,there was a slight bit of play and after i cleaned and greassed them up i left a very small amount of play again so I'm guessing tightness is not the issue ? I'm thinking bearing failure is the issue but before i go ahead and change them again i would like to explore all avenues first as the one set of bearings i looked at looked ok after cleaning them i can be very unlucky at times ,this could be one of those times but hey I'm up for more advice
    cheers lucus30 i like your advice
    84 Post(s)
    http://www.nissanpatrol.com.au/forum...ghlight=swivel
    Have a read of Mudrunner's thread. What brand of bearings were put in and which grease was used?
    I use the Innox mx8 Water resistant, high temp, high speed and high pressure grease. If moisture ingress does occur the bearings should be okay?
  6. The Following User Says Thank You to mudnut For This Useful Post:
    22 Post(s)
    Thats after the167-196Nm, thats pretty important
    96 GQ coil/Cab
    08 G6eT
  8. The Following User Says Thank You to Ben-e-boy For This Useful Post:
  9. #6
    Sep 2013
    16 Post(s)
    Of course after the preload should have mentioned that
  10. The Following User Says Thank You to lucus30 For This Useful Post:
  11. #7
    Sep 2013
    That is a good point one set of bearings were replaced the other re greased but not sure as to which was replaced or what grease was used . i looked at the drivers side and re greased them with Castrol HT GREASE for vehicles with front disc brakes with temperature range up to 200 degrees but made no difference
  12. #8
    Sep 2013
    16 Post(s)
    Quote Originally Posted by mudbug View Post
    I used castrol htb 2 but probably next time I'll look at using a water resistant one but not sure what to use honestly
