Results 1 to 6 of 6
Thread: Is Delo 400 Multigrade 15w-40 ok for gu crd even though Nissan recommend 10w-40 ?
    Jul 2014
    Hill End NSW
    Hi All,
    As above, is this ok for CRD? even though manufacturer recommends 10w-40 and Delo 400 from what I read says for pre 2007 engines? Looking to do my first oil change on my 2010 gu crd and just want to make sure I am doing the right thing.
    Renee
    most here that use Delo 400 have Di motors from memory.
    but there is plenty written on this, Have a search and see what comes up
  3. The Following User Says Thank You to threedogs For This Useful Post:
    hybrid (26th March 2015)
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Unless your climate is going to be below -10 deg, it should be fine.
  5. The Following User Says Thank You to 4bye4 For This Useful Post:
    SUCH IS LIFE Maxhead's Avatar
    ACT
    It meets all API and JASO standards required for the CRD so no reason not to use it. As stated above unles you drive in extreme temps it will be fine.
    I've used it on my last 2 patrols, both CRD's
    ________________________
    ______ 2017 D-Max _______
  7. The Following User Says Thank You to Maxhead For This Useful Post:
    hybrid (27th March 2015)
  8. #5
    May 2011
    I've used delo400 on my CRD for the last 20,000kms, it loves the stuff..
  9. The Following User Says Thank You to matto9018 For This Useful Post:
    hybrid (28th March 2015)
  10. #6
    Patrol Freak kevin07's Avatar
    georges hall
    mate save yourself grief 10-40 is recommended just stick to it. it has been well written about on here about using the correct oil personally I use penrite
    13 y62 the beast that burbles
  11. The Following User Says Thank You to kevin07 For This Useful Post:
