Page 13 of 14 FirstFirst ... 11121314 LastLast
Results 121 to 130 of 133
Thread: IceY60´s Patrols.
  1. #121
    Patrol God Stropp's Avatar
    38 Post(s)
    Quote Originally Posted by IceY60 View Post
    Hit another wall today. I went to my friend to help him with a preassure regulator. A took to 16" rims with me to try on hes patrol. One with 12cm backspace and the other with 13cm backspace. It seems that I can only have 11cm of backspace on the rims. So It will be alot of work to modify them :/ But good things happen slowly so I´m not stressed about it. This problem is because of the lift. then I need lift for the steering also. There is special bracket made be a company here in Iceland And it wil only allow 11cm of backspace on the rims. I´ll have to call the company and check if they can modify it in some way for me.
    good luck mate, i hope you can get the mods done that you need.
  2. #122
    Oct 2013
    East of Iceland
    After speeking to another friend. We came to a solution. We wil make this braket our selfes. After that send it to a special company that who inspect the welding. And if everything goes right we wil get a stamp on it wich alows me to use this bracket
    Best regards Gisli
    Nissan Patrol 1994 38" tires 5.42 diff ratios. The big one
    Nissan Patrol 1994 33" tires Stock family car. The small one
    Where the road ends, the fun begins
  3. The Following User Says Thank You to IceY60 For This Useful Post:
    Stropp (26th November 2014)
  4. #123
    38 Post(s)
    good work, inhope tou can get it approved
  5. #124
    Oct 2013
    East of Iceland
    One question. Does the TD42 have electrical throttle in Y61 like the RD28T? Or is it just like on the Y60 wire from the pedal??
    Best regards Gisli
  6. #125
    Pretty sure its mechanical as in a cable
  7. #126
    Oct 2013
    East of Iceland
    Hi mates. Whell after alot of thinking and trying to make up my mind I finaly decided to keep on the my cummins dream. I found an 90 model engine with only 110km on the clock. 727 auto and NP203 transfercase. I decided that the the 727auto tranny would not be used. So I started looking for an manual gearbox. I found a guy that want to trade the 727 for an T5x2276 gear box from an Daf truck. It´s quet easy to make the NP203 fit on the gearbox. And a friend of mine has a patrol with 5,9 and getrag360 gearbox np 203 and the patrol transfercase. So he is going to draw the plate that I need to bolt together NP203 and patrol tranny.. After alot of thinking about tires I decided to start with 44"dic cepec tires. And later try the 46" tires. Now I´m waiting excited at home to hear from a another friend that is going to look at the cummins engine for me. I´m bying this engine for alot of money and its over 700km away from where I live. So getting an person to look at the engine is very important. Hoping to seal the deal tonight
    Best regards Gisli
  8. #127
    38 Post(s)
    good luck mate, i hope it all works out and i look forward to pictures of the progress on the build
  9. #128
    Oct 2013
    East of Iceland
    Thanks mate. Just sealed the deal. So the new engine is mine now
    Best regards Gisli
  10. The Following User Says Thank You to IceY60 For This Useful Post:
    Stropp (3rd February 2015)
  11. #129
    38 Post(s)
    Awesome, look forward to the pictures of the conversion
  12. #130
    Oct 2013
    East of Iceland
    The engine is in a storage for now. Hoping to get started next month. Lots of measuremnts need to be done. I´m looking for an gearbox. getrag 360 or NV4500. The T5x2276 wil to much problem to install. And I´m not that into using the 727auto tranny that comes with the engine.. I´m hoping to get the beast running in a few months. There is alot of custom making that has to be done wich will cost alot of money. for example building toghether NP203 to the patrol transfercase. drive shafts, and so on. By the way does anyone now the name of the patrol transfercase?
    Best regards Gisli
  13. The Following User Says Thank You to IceY60 For This Useful Post:
    Stropp (10th February 2015)
