Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: dawes and needle valve installation
    Aug 2014
    gray nomad
    Hi all . Does any one have photos of installation of dawes and needle valve on a crd motor 2008.
    Mar 2013
    NE Melbourne
    Are you looking for an installation diagram or just where to position the dawes/needle valve?
    Pages and pages written on this subject with great diagrams as well, have a search for anything written by Chaz Yellowfoot [guru]
    Between Chaz and Rumjas I dont think there is anything left to learn. have a search and see what you can find
    http://www.chaz.yellowfoot.org/Manua...Controller.htm
    Have a read of this ,plus it has a diagram on how to set it up
    ron1 (31st January 2015)
    476 Post(s)
    Quote Originally Posted by ron1 View Post
    Its identical to the Di engine apart from the location on the vacuum supply port. The Di motor, it's ontop of the from section of the motor, under the intercooler. The CRDs is on the upper left side of the motor.
    • Block all three ports on the control solenoid which is mounted next to the air box and under the intake pipe at teh air box.
    • From the vacuum supply, run the hose to the small T piece supplied with the Dawes.
    • Then from that T, run the hose to one side of the needle valve. Doesn't matter which side.
    • Then run another hose from the other side of the needle valve to the air resonator box. Which is located next to the control solenoid. It has a single port on it...
    • Thats the needle valve done. Now the Dawes...
    • From the small T the last port goes to the top of the Dawes. Any port of the two is fine.
    • The other port that is vacant goes to the turbo VNT diaphragm.
    • The last, larger port on the Dawes goes to your intake system to pickup boost pressure. You will need to either, drill and tap one of the steel intercooler pipes, drill and weld a threaded bung into the pipe, T into the boost pickup for your boost gauge or use one of those boost gauge adaptors sold on eBay.
    Adjusting is an other story....
    Dr Gary (31st January 2015), ron1 (31st January 2015)
    Gold Coast
    Adjusting is an other story....[/QUOTE]
    So Mudski, I have a 99% complete dual dawes setup--need to connect 3 hoses and I am done. As best I can figure out (with help from Chaz Yellow foot) there are four variables for tuning:
    Needle valve--start closed and open until actuator arm lifts, then close until it just touches stop screw
    TPS voltage to switch between maximum boost levels on the dawes--currently on at 1.6v and off at 1.0v
    Dawes "pop off" pressure-- Low at 10--12 psi, high at 18 psi. I preset these with a pressure gauge and external air supply. I will confirm each separately on the road.
    I am guessing I could play with boost levels, and the voltage of switch-over, but not much else.
    Am I over simplifying the process????
    Is blocking the solenoid ports just to keep crud out???
  8. The Following User Says Thank You to Dr Gary For This Useful Post:
  9. #6
    Gold Coast
    Ron1
    Check your Private messages
  10. The Following User Says Thank You to Dr Gary For This Useful Post:
  11. #7
    476 Post(s)
    Quote Originally Posted by Dr Gary View Post
    Is blocking the solenoid ports just to keep crud out???[/QUOTE]
    I cant help you much on the dual dawes via the tps. I have never attempted to do this... As for blocking the three ports. You are correct.
    Dr Gary (1st February 2015)
  13. #8
    Mar 2013
    NE Melbourne
    I have a quick question regarding the setup of the needle valve. I have set mine up without a connection to the Air Filter Resonator and it works well. What are the consequences if any of not having a connection there?
    Chaz notes the reason for the connection as: "A clean air supply is needed to reduce the vacuum signal and its taken from the Air Filter Resonator, which is the same source as the ECU Solenoid Valve uses from "Port C"."
    If the vacuum signal is not reduced does it cause more wear on the dawes and needle valves? I was told by the turbo place where I purchased the dawes to just bypass the whole lot and like I said it works fine.
  14. #9
    476 Post(s)
    Quote Originally Posted by Rock Trol View Post
    Not true mate. What will wear out in the needle valve? Nothing. Theres no moving parts. The Dawes has a spring and a ball made of steel. It would take years before the brass housing would wear out too where the ball sits...the spring does lose its compression over time but thats just wear and tear. Easily replaced and cheap.
    You don't have to plumb it into the air reso box, it will work still but if you were to NOT plumb it there I would put a small inline filter of something on the end of the line so it filters the air its sucking in. You can "feed" this same line with boost pressure. But you will need to re adjust the entire system. Some people have reported some power gains doing this. I did it, felt nothing, but I was not used to how my boost gauge was reacting and the car performing differently so I went back. I'm experimenting now with different weight balls in the dawes. I'm surprised on the differences so far in just changing the ball weight.
  15. #10
    X2 with mudski...
    No needle valve then it is a closed loop and no problem but if you use a Needle Valve I would stick with Chaz and plumb your atmospheric line from after the air filter.
    If you don't it means that the Vac pump is open to unfoltered air and also every time the Dawes operates it will be porting unfiltered air and therefore any contaminants into the Turbo Actuator Diaphragm and the Dawes itself.
    As suggested a good quality filter on the atmospheric side of the needle valve will also do the job
    Might not be a biggee to 90% of vehicles but in a Patrol that runs in dirt, dust, mud, water etc I would def use one
