Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Dual battery, s
    Expert coop's Avatar
    Dec 2014
    Righto, thanks guy's I'll keep you posted
  2. #22
    Dec 2014
    i used a battery link kit and it worked awesome. i got it cheap at autobarn on sale..
    also i used a optima yellow top. but if i could do it again i would go full river.. higher CCA, cheaper and bigger capacity for the same money.
  3. The Following User Says Thank You to aazn For This Useful Post:
    coop (24th December 2014)
  4. #23
    Dec 2014
    G, day all, I've finally decided on the redarc bc/dc 1225 and an optima yellow top mounted in my draws as I think this will be the best position close to the fridge, so thanks for all of your advice. Cheers guy's.
  5. #24
    Advanced Flex's Avatar
    Sep 2011
    Melbourne, Australia
    One thing you need to consider is the loads that will be running off your second battery. If you are running device which pull more than 25A (the 1225 maximum output current) your battery will never charge or will very slowly as the BCDC1225 can't give out enough current.
    For example my second battery runs my amplifier, head unit and fridge, which on average draws around 20-25A so with BCDC1225 there would be no current left to charge the battery. Also the BCDC1225 will reduce it's output current if the ambient temperature goes above 55 degrees C which can happen if mounted under the bonnet on a hot day.
  6. The Following User Says Thank You to Flex For This Useful Post:
    coop (9th January 2015)
  7. #25
    Dec 2014
    Maybe I should go with the 1240 ?
  8. #26
    Mar 2013
    NE Melbourne
    If you are running the fridge, charging phone/laptop and LED lighting off the rear battery then the 1225 would be enough. A 1240 will charge quicker though. Have you decided what do you want to use the battery for? It might just be cheaper and simpler to put a wet cell under the bonnet with a normal VSR. It would save heaps of money and still be the most versatile option as you can use as starter, help with winching, big amp etc.
    I have a redarc 1220 and Dekka AGM battery under the bonnet. It has worked well for the last couple of years but I am noticing the battery does not seem to hold a charge as well as it used to. Will monitor the situation, but unless I get 5-6 years out of the battery then it was not a cost effective way to go. I would have been a lot better off staying with the VSR and lead acid battery set up that the car had when I bought it.
  9. The Following User Says Thank You to Rock Trol For This Useful Post:
    coop (12th January 2015)
  10. #27
    Dec 2014
    It's mainly going to operate the fridge, led lights and a 300w inverter, im not running a winch at the moment but am looking at fitting one in the future so I might look at an under bonnet option when i get one. Thanks for the advice guys. Cheers Tony.
  11. #28
    Oct 2011
    Essendon
    Quote Originally Posted by Rock Trol View Post
    If you are running the fridge, charging phone/laptop and LED lighting off the rear battery then the 1225 would be enough. A 1240 will charge quicker though. Have you decided what do you want to use the battery for? It might just be cheaper and simpler to put a wet cell under the bonnet with a normal VSR. It would save heaps of money and still be the most versatile option as you can use as starter, help with winching, big amp etc. I have a redarc 1220 and Dekka AGM battery under the bonnet. It has worked well for the last couple of years but I am noticing the battery does not seem to hold a charge as well as it used to. Will monitor the situation, but unless I get 5-6 years out of the battery then it was not a cost effective way to go. I would have been a lot better off staying with the VSR and lead acid battery set up that the car had when I bought it.
    AGM's typically don't like under bonnet installation.
    Sent from my iPhone using Forum Runner
  12. The Following User Says Thank You to Drewboyaus For This Useful Post:
  13. #29
    Quote Originally Posted by Flex View Post
    You cant just say your applications are drawing 25A and the 1225 is to small.
    The fridge for example may draw a maximum of 5a/h but how many amps per hour?? Might have a duty cycle of 20% so in reality it's only 1a/h.. (example only)
    Same with amplifiers. They state maximum amp draw. If your only listening to soft music the draw will be much less.
    Anyway imo the ctek 1225 is a good choice with a good battery, mounted in the back.
    I wouldn't worry about dual battery while winching, you winch with motor running so the alternator is doing most the work..
  14. The Following User Says Thank You to BigRAWesty For This Useful Post:
