Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Long range sub tank
    Jun 2011
    Rockhampton Q
    Long range sub tank
    Hay everyone found a bigger sub tank out of a 2000 4.2 wagon just wondering will it fit in my 2008 crd 3L wagon
    475 Post(s)
    According to LRA's website, they are all the same for the wagons from 1998. So I reckon your safe.
    http://www.longrangeautomotive.com.a...art&Itemid=214
    sr06 (4th January 2015)
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    I reckon you should be ok is it 70l,s
  5. The Following User Says Thank You to Sir Roofy For This Useful Post:
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    as long as its a GU one, you will be ok
    my long range tank came out of a 4.5 petty
    a bit of a mess around to get the original tank gauge to work.......... but it did in the end
  7. The Following User Says Thank You to Bigcol For This Useful Post:
  8. #5
    Expert Agronaught's Avatar
    Sydney, NSW
    Well worth the effort though. It's probably the best upgrade I've done on my tb48. I use it every time I fine the car
  9. The Following User Says Thank You to Agronaught For This Useful Post:
  10. #6
    Jun 2011
    Rockhampton Q
    image.jpg not sure on the size and thanks for the in put everyone
  11. The Following User Says Thank You to sr06 For This Useful Post:
    Stropp (4th January 2015)
  12. #7
    Expert billyj's Avatar
    gordon
    i reckon that one pictured is probly for a ute, looks way too tall to fit under a wagons floor
  13. The Following User Says Thank You to billyj For This Useful Post:
  14. #8
    Jun 2011
    Rockhampton Q
    Old mate said it's out of a wagon and won't fit in a swb ute
  15. #9
    Patrol God Stropp's Avatar
    36 Post(s)
    Looks like mine, will be ok
  16. The Following User Says Thank You to Stropp For This Useful Post:
  17. #10
    Jun 2011
    Rockhampton Q
    So that should be a 70ltr stropp? Would it bolt straight in and use the same sender and plumbing?
