14th March 2011, 10:50 AM
14th March 2011 10:50 AM
14th March 2011, 11:03 AM
1a, The only difference between GQ and GU H233b rear diffs is the width, GU is 40mm wider.
1b, H260b rear diff out of coil sprung wagons (fitted to 4.5 petrol, early 4.8 petrol and 3.0l diesel all with manual gearbox only) is stronger and same width as GU H233b. Lockers are more expensive for the H260b diff and ratio's are limited.
2a, H233b Yes straight bolt in swap.
2b, H260b Straight bolt in but may require different driveshaft from the donar vehicle.
3, Suspension components are the same.
4, 40mm
5, If you are planning on BIG horsepower then fitting the H260b probably is a good idea, though most people will never find the limits of the smaller H233b.
Tony
The Following User Says Thank You to YNOT For This Useful Post:
growler2058 (14th March 2011)
14th March 2011, 11:12 AM
14th March 2011, 03:15 PM
I am he, fear me
Hey Tony... quick hypothetical
If one was to do the diffs as a full "roll out GQ/ roll in GU" differential and housing exchange you would have to revisit your rim offset as well due to the wider track, Yes ?
14th March 2011, 04:01 PM
the evil twin
A lot of it will come down to your particular vehicle, what suspension and wheels you have. I have done the diff swap you're talking about and had trouble with the tyres touching the outer guards and flares. My wheels are about -12 offset.
Tony
14th March 2011, 04:23 PM
I am he, fear me
YNOT
Tony
Cool...suspected as much.
27th April 2011, 11:15 PM
thanks for that info ynot, a mate is about to do this and will find the info usefull!!
21st December 2014, 05:08 PM
#8
I am looking at doing the same swap, is there any work involved when it comes to switching to disc brakes on the rear ie swapping brake booster and master cylinder or any changes to brake lines?
