Just to briefly touch on wire sizes again, here's a pic showing 35mm2 compared to 50mm2.
I upgraded all my winch cabling to 50mm2 and still drop 2 volts
John
Here are the Terminal Boots Kallen. You might get something like this from Jaycar too.
http://smithiengineering.com.au-warn-electrical-terminal-boot
These will fit a 35/ 70mm2 wire and just need a bit of hot water to make them pliable.
I have purchased a bulk of these for each of the terminals on the winch and alternator.
Its a Nissan! =====> Its a Keeper!! ....... Got a TD42 in it BONUS!!....... I'm a lucky bugger! I've got 2 of em!
BigRAWesty (18th December 2014)
I have the Ridge Ryder 12000 from Supercheap. I have nothing to measure that kind of current but these winches are typically rated around the 450 - 500 amps when pulling hard with a few layers of rope still on the drum.
I did a thread in DIY showing how I installed it all.
John
I'd be interested to know what others are seeing on their voltmeters while winching..
John
John
Would be interesting for sure.
But are you reading the 2v drop at the battery while winching?
Or is that the difference between battery and winch terminals?
I'm reading it directly from my Ecutalk display. That's the voltage that the ECU sees. Had 13.5v on high idle, it dropped immediately to 11.5v every time I hit the controller button.
I was attached to a tree with brakes locked and I was re tensioning the dyneema rope.
Battery is a new Century.
John
MudRunnerTD (18th December 2014)
Yes I agree with Kallen, that is Load Cell drop rather than voltage drop. Voltage drop is the difference between the source and the load, rather than the source because of the load. If you had 2 guages and one at the battery and one at the winch voltage drop would be the difference between them.
