[QUOTE=Rocket55;558774]The supplied fairlead was spot on. It utilises the top bolt holes that hold the winch in. You will need 10mm longer bolts for this.
What did you do with your number plate? Did you just put some hinges on it so you can fold it up when using the winch or is there a better option?
Something like this? http://www.uneek4x4.com.au/bull-bar-number-plate-flip/
