Page 58 of 220 FirstFirst ... 5657585960 ... LastLast
Results 571 to 580 of 2192
Thread: AB's new GQ is finally here
  1. #571
    I like your thinking Andy, rivets sounds a good idea but you definitely want the washers
    I like the idea too
    Bearing Wholesalers and another local bolt shop don't have them that small though.
    Needs to be 3mm hole and minimum 8-10mm size washer.
    Need to head into the big smoke = Bayswater
  2. #572
    If not I'm sure you could make some. You'll need to put heaps of rivets into it though, they need to be close together
  3. #573
    You can get quite large heads on rivets if you require it. You might get lucky and get one with an 8mm head.
    What about nutserts?
  4. #574
    Legendary Alitis007's Avatar
    15 Post(s)
    Why not make your own with a hole saw ??
  5. #575
    If I can't find them then yep, was thinking that too.
  6. #576
    If this doesn't happen then nutserts was my second choice.
    They would have to be small though.
  7. #577
    We use stainless steel rivets at work. I have buckets of them
  8. #578
    Feb 2011
    Shed
    45 Post(s)
    I'm considering mounting the Bushranger flexi flares using stainless steel pop rivets and I'm trying to find some washers to suit just in case it pulls through the rubber.
    The custom folds are tight (would still work using bolts but tight) and it would make cleaning mud easier as well. I do not want to drill screws or tek screws in there, I can't stand that!
    Thoughts on this? Haven't seen many people doing it so I'm second guessing...lol
    Being to a few local shops and no joy on washers that small either?
    I used rivets and the screws that came with them
  9. #579
    No rivets in my box, just self tappers.
  10. #580
    Feb 2011
    Shed
    45 Post(s)
    Rephrase
    I used rivets AS WELL as the self tappers that came in the box
  11. The Following User Says Thank You to growler2058 For This Useful Post:
    AB (3rd December 2014)
