Looking good mate, it must not have been too hard to install it as it only took two beers.
Oh and I'd get it moved to member rides stops all the "welcome to the forum" crap when clearly you've been here longer then they have
I also see you went the LED indicators in the bar, I need to get myself some of those one day. As already said that plate where the solenoid can go is as simple as giving it a whack with a solid hammer, it'll pop right out and never go back in (without welding). So decide if you want the solenoid there or somewhere else before you get the hammer out? I have mine there. The winch itself is easy enough to install, you just take the guard off underneath and push the winch up from the bottom.
The guard underneath? Guessing I'm missing that bit because I could lift up a winch from the bottom easy as nothing to stop it.
