Results 1 to 10 of 517
Thread: Blocking the EGR Valve
Threaded View
    Quote Originally Posted by DOG View Post
    TIMOO just be fore I put this plate in (egr block) do I have to do any other mods ?? The motor is a 2010 mod zd30 crd I don't know what else has been done except a after market welded inter cooler , extra fuel filter , and a new air flow senser , thanks .
    If you have a boost gauge I wouldn't block the egr as your boost will be all over the shop and you be constantly looking at your gauge. Worse than pre egr. If you don't have a gauge then you won't see the gauge bouncing up and down and you won't need to worry. Lol.
    If you want to give your turbo a smooth linear boost curve, you need to install a Dawes and needle valve. Not a must mod but definitely well worth it.
    DOG (8th October 2014)
