Page 3 of 19 FirstFirst 12345 ... LastLast
Results 21 to 30 of 187
Thread: Checking and cleaning MAF sensors
    GQ diesels had mechanical injector pumps so no MAF sensor.
    Tony
  2. The Following User Says Thank You to YNOT For This Useful Post:
    lachiek (1st March 2011)
  3. #22
    Expert lachiek's Avatar
    Sydney CBD (for my sins)
    Great thanks Tony.
    I'm not going mad and since I've just found out this plus the fact I already have a EGR shim I'm off to the mech to get the injectors done to hopefully stop the cloud of black smoke...
    Cheers, Lachie
    GQ Safari 2.8TD. BFG AT's / Safari Snorkel / Straight thru exhaust / Lots of electrical mods
  4. #23
    Mar 2011
    Quote Originally Posted by ashbee37 View Post
    hi Just wondering if the new maf sensor fixed this prob or not??
    Hey mate, I had the same problem with it going into limp mode under load, lift off the accelerator then power on again and it comes good for a while. For me it seemed no matter what rev's I was at, if it stayed over 11psi for more then say 10 seconds it went into limp mode.
    Replaced the maf with a genuine nissan sensor and no more overboosting limp mode.
    I've also blocked my egr, and put a dawes and needle valve on.
  5. #24
    Thanks for the feedback ergjan.
    Welcome to the forum, when you get a minute drop by the introductions page and tell us a bit about yourself and your Patrol.
    Tony
  6. #25
    Expert Pete's GU3's Avatar
    Jul 2010
    Melb. east
    I just wanted to say that having done the maf sensor a couple of times using that spray, as demonstrated on this thread , i'm pleased to say that having done some day trips around the outskirts of Melb. recently and pushing the GU3 3lt td through the hills pretty hard , it did not let me down 1 bit , no loss of power at all , just spot on , actually put a smile on my face . now i have some confidence to go bush, DEEEEP bush .......!!!!
  7. #26
    Good on ya Pete, we just need to get that sub tank sorted now.
    Tony
  8. #27
    Patrol God nowoolies's Avatar
    Perth
    Tony
    time for you to move over this way we want a good mechanic here
    could be a change from chilli hot dogs lmao
    Last edited by nowoolies; 13th March 2011 at 07:04 PM. Reason: keyboard made a typo
    HELL NO !!!!!!
  9. The Following User Says Thank You to nowoolies For This Useful Post:
    YNOT (13th March 2011)
  10. #28
    Patrol God Bob's Avatar
    Oct 2010
    Pakenham
    47 Post(s)
    Tony How long would leave the Battery disconnected after cleaning the MAF
  11. #29
    Half an hour should do it.
    Tony
  12. #30
    Banned Bigrig's Avatar
    Oct 2010
    South of Brissy, QLD
    Quote Originally Posted by YNOT View Post
    Tony
    Unless you're trying to clear error logs from the ECU - I left mine overnight to be sure when I had the coolant temp sensor problem, but I believe the manual states it can take up to 24 hours for a manual reset (battery disconnect) to clear all errors.
