Page 412 of 1057 FirstFirst ... 410411412413414 ... LastLast
Results 4,111 to 4,120 of 10561
  1. #4111
    176 Post(s)
    I did start re-wiring the tow harness, but I'm too comfortable now with a few empty cans... It can wait.
    Patrol Guru
    May 2011
    mackay former alice boy
    Umm maybe when you are doing trailer plugs try this .When I was doing a lot of bush work on dirt and corrugations driving road trains we used to wire everything so it worked then separated all the plugs (male and female) and filled them with silicon that stopped bulldust , water ,vibrating out ,and gunge shorting every thing out . In the case of Catwomens photo I would mount to where the 4 holes were for the tie down point using the female plug mounting points .
  3. #4113
    176 Post(s)
    Perfect weather for a few drinks, a new filter and a MAF clean.
    Attachment 49520
    Nov 2010
    Getting a life...
    38 Post(s)
    Quote Originally Posted by dads tractor View Post
    The thought crossed my mind, but I didnt want it directly above the towball..
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
  5. #4115
    475 Post(s)
    Fitted some led globes in the rear, plus some resistors for the indicators. Also finally fitted my reco'd winch back in. And fixed my issue of the screen on the head unit flashing with the rhs indicator when the brake pedal was press. Lucky find really. Removed the rhs rear indicator socket and ran a wire from the earth lead to the chassis and it worked straight off. That was easy... wish every fault was that easy to find. Plus I put my Stebel horn back in....
  6. #4116
    Patrol Guru Rocket55's Avatar
    Sydney
    Fitted LED front parkers and blinkers into the Bullbar and fitted my Runva 11XP winch and some bling winching LEDs.
    Cheers Rod
    My Build 2005 TD42TI
  7. #4117
    Need to either charge my Aux battery and test or chuck it and buy a new one.
    Must also clean the MAF and change the air filter before going away this weekend,
    plus add some Castrol T2 and some Nulon injector cleaner
  8. #4118
    Western suburbs of Melbourne
    11 Post(s)
    Quote Originally Posted by Rocket55 View Post
    Can't see the pics. Oh yeah. You didn't put up any. Lol
  9. #4119
    11 Post(s)
    Need to find why I don't have any indicators and brakes on the non dummy lights. Reverse lights work but nothing else. All fuses are good.
  10. #4120
    .......... TPC's Avatar
    63 Post(s)
    I thought the reverse light was the only thing that did work and the other lights were in the bumper.
