Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: What's the best 2" kit to get ?
    Yeah still cant see the bottom of the bump stop. is it Split or anything? hard to tell from that pic.
    Ghee on closer look here though it looks like it has spent some time on that bump stop mate! cant really tell but does look shagged by the jagged look of the bottom that i can just see.
  2. #22
    Advanced NoRush's Avatar
    Aug 2014
    Clarence Valley
    the part remaining of the bumbstop seems to be in good order nice and solid still but this bit here i found wound in the spring once side is sharp jaggered the other smooth i figure this is what im missing off them any need to replace ?
    2.8LTD GU ST, Arb winch bar, tigerz11 dominator 12000lb winch, safari snorkel, black widow rear draws, roof console, 2 uhf's,
  3. #23
    Yeah Nah she's Knackered mate. You will probably find a set at a Wreckers though. a dime a dozen.
    The rear ones are bolted to the chassis and are a triangle shape hanging down under the chassis rail.
  4. #24
    Aug 2014
    Clarence Valley
    Cheers mud will call around the wreckers tomorrow and see what's about
    The rear ones look perfect !
    Do the rears springs have those rubber seats to ?
    Thanks again for all your help !
  5. #25
    Aug 2014
    Clarence Valley
    Well 2" ome purchased today, decided to get arb to install it for peace of mind for warranty since this is my first suspension upgrade, will be installed Monday week will post some before and after shots once it's done
    Thanks for everyone's help have saved a few bucks here and there and very happy
  6. The Following User Says Thank You to NoRush For This Useful Post:
    Hodge (19th September 2014)
  7. #26
    Oct 2011
    Essendon
    You won't be disappointed mate. It will handle better than new with the new kit in.....
    Sent from my iPhone using Forum Runner
  8. #27
    Feb 2011
    Shed
    45 Post(s)
    Quote Originally Posted by Brenttp View Post
    Take a measurement from the centre of wheel/axle up to the guard before and after and see the difference. Youll know how sagged your old setup was
  9. The Following User Says Thank You to growler2058 For This Useful Post:
    Drewboyaus (20th September 2014)
  10. #28
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    Agree, measure all four corners too ,so if you have a levelling problem after fitment, you have at least obtained a "before" measurement.
    Also measure from the road to your roof height , my springs had sagged that much, after I fitted my 2" lift ,the roof actually ended up 4" higher than before !
