Page 404 of 1057 FirstFirst ... 402403404405406 ... LastLast
Results 4,031 to 4,040 of 10561
  1. #4031
    FNQGU's Avatar
    Jun 2013
    Cairns, Queensland
    21 Post(s)
    Re-positioned the ATF cooler for better airflow. Now to find some steep hills to test it all out and decide whether or not I need to also fit a fan.
  2. #4032
    Apr 2014
    Finally got around to putting the Dynamat Extreme and Focal BAM in the doors and rear quarters..much much quieter now..wired up the driving lights..but they got to go as hi beam drowns them out lol started making the new plate to hold my diff breathers, enlarged the hole in the firewall (where the clutch would go through on a manual) so that that I could run all my wiring into the cab and made a new cover plate for it..
    Next is to work out where the 24-12v reducer is going and to make a new bracket to hold my phone cradle..
  3. #4033
    333 Post(s)
    Made the twin battery tray for the 24v bank to go in the footwell behind the passenger seat yesterday. After doing all the welding then grinding it all down and realising I have achieved Fark all penetration I turned the bloody welder up and do the whole thing again!
    Got a little more to do to it today then its ready to mount.
    Bring on a 24v Himount!! Hell yes we will!!
  4. #4034
    What's a 24V hi mount motor worth?
  5. #4035
    333 Post(s)
    I will use the warn 6hp12v motor on 24v. Will halve the current draw and double the speed and power of the winch. Crazy good.
  6. #4036
    Surely if the speed and power doubles the current draw would stay the same. Half current draw would be same speed and power. Surely?
  7. #4037
    82 Post(s)
    Electric motors also have induced currents (Generated by the magnetism inside the windings), which oppose the supply current. Higher supply voltages over come these opposing currents to an extent. MR won't quite achieve double speed or power, but it will certainly go a lot better.
  8. #4038
    333 Post(s)
    It will also draw far less 24v Amps and given the massive increase in Line Speed of the winch the Max Current draw will be less for far less time making a 55amp 24v Alternator plenty of output.
    The trade off is an isolated 24v charging and storage system on a 12v Car.
  9. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    mudnut (31st August 2014)
  10. #4039
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Flogged it hard ;-)
    Hello from Under Down Under!
  11. #4040
    Patrol Guru
    May 2011
    mackay former alice boy
    Taz you have fun cleaning that I've just spent 4 hrs cleaning the young fellas patrol tray after he spent 5 minutes in some quality black soil mud .
