Page 35 of 81 FirstFirst ... 3334353637 ... LastLast
Results 341 to 350 of 807
Thread: EFI to Diesel conversion.
  1. #341
    Why not just run an external cooler? Saves you stuffing about and you could get some rubber line and a cooler for $30-40
  2. The Following User Says Thank You to nissannewby For This Useful Post:
    Bloodyaussie (18th August 2014)
  3. #342
    Why do you keep ringing Patrolapart if you never get good service?
  4. #343
    Thomastown, Melbourne
    6 Post(s)
    Shut up thats why!!!!!!!!!!!!!!!!!!!!!!!!!!
    Yes Matty I was looking at it and I think I could use my efi cooler and make that work... I was staying out of the engine bay today so did not dig deep into working out what would work.
    As its not on the pressure side it matters not that I use lots of hose?
  5. #344
    No it doesnt matter although its better to keep hose to a minimum. A small aftermarket one mounted closer to the drivers side so then you can use about a metre of hose just to get out to the cooler. Just remember the more hose you use the more likely it can rub so tie it well or even use a sleeve on some sort.
  6. The Following User Says Thank You to nissannewby For This Useful Post:
  7. #345
    Why don't you answer my phone calls?
  8. #346
    Patrol Guru Family4x4's Avatar
    Jan 2014
    Victoria
    Try Readies, I can pick parts up from them and get them to you. I have always found them reasonable. Clint who will probably answer the phone owns the place and is more than helpful.
    http://www.readies4x4.com.au/
    In any moment of decision, the best thing you can do is the right thing, the next best thing is the wrong thing, and the worst thing you can do is nothing.
    Theodore Roosevelt
  9. #347
    476 Post(s)
    Yeah mine too!
  10. #348
    I'm not sure Chappy's Avatar
    Jul 2014
    11 Post(s)
    Cannot for the life of me get this clutch fork back together... I can't believe this is what's stopping me from finishing the conversion. Just about ready to bin the whole lot.
  11. #349
    Quote Originally Posted by GQJETT View Post
    From memory didn't seem to have any dramas with the clutch fork. It was a while ago tho and I did have a mate who knew what he was doing help.
    Good luck, if not I bags the motor!!
  12. #350
    Patrol Guru Irish's Avatar
    Also try Allied in Dandenong South, they have been great when I've used em, they're just off eastlink, or 10mins from my house.
