Page 14 of 35 FirstFirst ... 1213141516 ... LastLast
Results 131 to 140 of 343
Thread: Installing WRX front mount intercooler with 3" pipe to GQ
  1. #131
    Patrol Freak krbrooking's Avatar
    Beveridge, Melbourne
    Looks good Andy. Sounds like you have been having fun.
    Sent from me using Forum Runner
    Live life, Love life.
    Snatch straps on towballs can harm and/or kill!!!!!!
  2. The Following User Says Thank You to krbrooking For This Useful Post:
    AB (6th August 2014)
  3. #132
    In theory would one expect higher egts if they had a boost leak or the wastegate was slightly open all the time?
    Less air, less boost, making it run more rich?
    Not comparing my non ic to ic just a question in general...
    If the lever on the wastegate arm was correct and holding correct boost then one should expect lower egts then if it was half open surely?
    If boost was down then yes as you say it will be richer and slightly higher egts. But you could run no boost in your setup and egts should fine.
    If I get the chance one time I would like to check egts on a na engine I think it would be quite surprising.
  4. The Following User Says Thank You to nissannewby For This Useful Post:
  5. #133
    That would be interesting actually!
  6. #134
    Doesn't kallen have an EGT gauge on his?
  7. #135
    No. He has purchased a cheapo gauge but I dont believe he has fitted it. If he sees this it would be cool if he could and post some results.
  8. #136
    Hey westy if you see this mate I would also be very keen to read your egts too bud if you get a chance???
  9. #137
    Finally!!
    Boost back up to normal, feeling more power then previous, egts have dropped, it's all coming together, thank bloody god!
    I'm done gents and one happy camper!
    Getting this tuned properly and it will be a weapon for now until i can upgrade later on!!
  10. #138
    That's great news Andy! Can't wait to see it
  11. The Following User Says Thank You to Winnie For This Useful Post:
    AB (8th August 2014)
  12. #139
    Finally!!
    When you get it tuned ask them to put some timing into it.
  13. The Following User Says Thank You to nissannewby For This Useful Post:
  14. #140
    Matty.jpg..................
