Results 1 to 10 of 16
Thread: instrument cluster troubles
Threaded View
  1. #6
    84 Post(s)
    G,day, wannabe. Have a look at this thread for info about adjusting the speedo :
    http://www.nissanpatrol.com.au/forum...=adjust+speedo
    And this to check the wiring too the speedo:
    http://www.nissanpatrol.com.au/forum...peed-sometimes
    There is some simple tests to check the Fuel Sender in the manual.
    The sender should range from 4.3 to 5.7 ohms at FULL. 74.3 to 84.8 ohms at EMPTY.
    The wiring to the voltmeter is a yellow/red wire (ignition) and it supplies the speedo, fuel gauge via the printed circuit on the back of the cluster. This is a TB42E gauge cluster. The purple arrow, (under the yellow arrow) should be the ignition wire that supplies the voltmeter.
  2. The Following 2 Users Say Thank You to mudnut For This Useful Post:
    MudRunnerTD (28th July 2014), wannabeturboed (28th July 2014)
