Page 13 of 15 FirstFirst ... 1112131415 LastLast
Results 121 to 130 of 150
Thread: Sound dampening..
  1. #121
    Ive thrown in 8 sheets to the front of the wagon (over the top of the dynamat) on the floor pan and a wee bit up the firewall and it has cut out more of the road noise. only cost 90 bucks and 20$ for a can of spray on adhesive.
  2. #122
    Expert Ronin's Avatar
    Brissy
    what about this product from Jaycar , seems to combine Buty and Foam
    http://www.jaycar.com.au/productView.asp?ID=AX3689
    2012 GU Patrol Simpson Edition. Auto. UHF, Bull Bar, 2" lift with Koni shocks, dobinson coils. 3" stainless Steel Exhaust.
  3. #123
    Quote Originally Posted by Ronin View Post
    I did look at that but it's only 3mm thick..
    It woukd be a good half way point.
    If your looking for a solid decrease then the only way to do it is mass loading the panels the a good thick layer of sound absorbing material.
    Brissy
    so compared to that, Luxary Liner Pro looks better
    Specification
    Sheet size = 24" x 54" (9 sq. feet)
    Thickness = between 1/4" - 1/2" (.25" .5")
    Mass/Area = 1.2 lbs. per sq foot
    Total weight per sheet = 10.80 lbs. per sheet
    http://store.secondskinaudio.com/lux...q-ft-4-sheets/
  5. #125
    That does look better on paper..
    Jul 2014
    has someone done yet a dampenig job for a Y60 gr
  7. #127
    Quote Originally Posted by GRY60 View Post
    Yep, we've only done y60's
    After what I've done there is a definitely difference how ever the main issue is motor noise for me (td42+t) if I cut that down she would be a silent killer.
  9. #129
    I think that's mission impossible mate. I doubled up the fire wall and still get engine noise. Greatly reduced but it's still there. I'm Na, so turbo should be better
    Sep 2010
    I have been through same process with dynamat throughout and main issue is also now engine noise (td4.2 + t) - I am looking at bonet lining to help reduce engine noise and wondering if anyone else has done this and if so what brands and success ?
