Results 1 to 5 of 5
Thread: Detailed Engine Pictures
    South Africa
    Can anyone help with some detailed engine compartment and underside pictures? I have a '99 4.5TB (Attila) which Swambo and I drag through the African "outback" on various remote and sometimes hairy adventures. Recently we had a really muddy trip which resulted in the engine looking like a muddy hippo and the front crank oil seal started leaking from all the mud that had probably been push behind the pulley (already fixed again with help from this forum).
    It then dawned on me that there is a splash cover missing under the front crank pulley and possibly some other splash protection as well. Unfortunately, in the area that I live I don't have any Patrols close at hand that I could crawl under and use as reference to rebuild missing protection. What does this splash guard look like or is there somewhere I could find a picture of one? Also, any advice on the subject will be greatly appreciated.
    It would also be great to get some other detailed engine compartment pictures to see what else has been rearranged during the early years of Attila's life.
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    Have a look in my recent thread DIY- winch install. In post #6 there's a pic of the plastic air deflector that fits under the radiator.
    There's no other "splash guard" under the crank pulley.
    Leaking front seal is pretty common..
    John
  3. The Following User Says Thank You to jff45 For This Useful Post:
    Conradk (25th June 2014)
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    As John said ^
  5. The Following User Says Thank You to 04OFF For This Useful Post:
    South Africa
    Thanks guys, really appreciate the response and pictures. I have the remnants of the plastic deflector still in place (the two bolt on strips) but had no idea of the size and angle. Will definitely begin fabricating one this week-end. I also like the diff protection as well. Provides a significant degree of cushioning in the bolder beds.
    Brisbane,QLD
    12 Post(s)
    Cool , i actually took those pics for Mal Harris who makes and sells the diff gaurds, you can purchase the diff protectors from Mal here......
    http://www.nissanpatrol.com.au/forum...No-Weld-Armour
    Mal also makes a rear diff gaurd now, great value, and peace of mind, looks good too, ive had mine powder coated white now (You can order most colours straight from Mal)
