Results 21 to 30 of 37
Thread: GU Wheel coming off at 110km/h
    Adelaide
    This doesn't happen with steel wheels - only alloy??
  2. #22
    Aug 2010
    Adelaide - Northern Suburbs
    Quote Originally Posted by outback View Post
    suggest you don't keep the torque wrench set at 133 return it to Zero after use. You may damage its spring/torque ability.
    Just a thought.
    I sent the hubby shopping for one
    Also, spoke to the garage owner today - and was promised a call by 10am tomorrow ..... but after 3 promises of callbacks from the other bloke, must admit i'm a little sceptical!
    But i'll give him the benefit of the doubt, and will wait until tomorrow morning to see what he says
    Hoping for something positive .... we'll see what happens!
    2006 GU ST 3.0td manual. CTEK 250S Dual Battery - Ironman 65L Ice Cube - Pioneer AVH-3600DAB - Tough Dog Adj 45mm Shocks, springs and HD steering damper - Airtec Snorkel - King Brown 3" exhaust
  3. #23
    Apr 2013
    newcastle, nsw
    Quote Originally Posted by Headhoncho67 View Post
    No. Its only the alloy wheels that have this problem. But it's hood habit to check your wheel nuts anyway.
  4. #24
    Aug 2010
    So, further update ....
    Spoke to Nissan, who confirmed there was no recall for this, but rather the indicators were supplied to allow you identify if the nuts had been correctly tensioned and re-tensioned.
    The official process is to check them by hand, tension in sequence to 60Nm, then tension in sequence to 133Nm.
    According to Nissan, the only reason they come loose is if they are not tensioned correctly as per this process.
    Spoke to the tyre place about this, and their process is to tighten by hand, then use the ratchet gun to tension them in sequence and then check them by hand. This is not tensioned specific to manufacturer specification, nor is it done in the two steps as recommended by Nissan.
    However, they says that because it took 2 weeks to come loose, and because of the Nissan 'recall' (they insist on calling it that) they will only offer us $300 towards the $2000+ work that is required.
    As you can imagine, not overly impressed, and I will certainly not be using TyrePower Gawler again. They also belong to the Cluse Bros chain here in SA.
    While I know this is a known issue, it's interesting that the wheels were fine for 10months, and then within 2weeks of being rotated & balanced, we have issues!
    Still planning to take it further! Will see what happens
  5. The Following User Says Thank You to tracemul7 For This Useful Post:
    Clunk (9th May 2014)
  6. #25
    Best of luck with it and hope you get the right resolution.... Oh and keep us informed on the progress
  7. #26
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    That's rubbish. Years ago my mum changed her car tyre and forgot to do the nuts up. They were only done up hand tight. It was only luck that I found 2 nuts missing and was able to sort it out. But it took about a week for the nuts that were only hand tight to work their way loose.
    Good luck!
    IMO and should be taken with a grain of salt.
  8. The Following User Says Thank You to Parksy For This Useful Post:
    tracemul7 (9th May 2014)
  9. #27
    Aug 2010
    So, further to my previous posts .... the garage in question have offered us $300 towards our excess. Costs have been estimated at $2250, so not happy with this.
    Nissan confirmed that the indicators are fitted to confirm that the wheels "have been correctly tensioned and re-tensioned as per the Nissan instructions for this vehicle", which is:
    - tighten by hand
    - tighten in star pattern to 60Nm
    - tighten in star pattern to 133Nm
    The garage confirmed how they fit the wheel, which is:
    - tighten by hand
    - tighten in star pattern to pre-set tension with their air-ratchet
    - check and tighten with hand brace
    Which is NOT how Nissan recommend, and therefore we are still saying they are to blame.
    A letter with all the facts has now gone to the state manager of this very well known chain .... we'll see what happens next!
    I am biting my tongue to stop me naming and shaming .... waiting on a response .... but not a happy bunny!
    We're still running on 5 studs on that wheel, and dont have a spare .... so we're very cautious about driving her at the moment.
    More updated coming when I have them
  10. The Following User Says Thank You to tracemul7 For This Useful Post:
    Clunk (21st May 2014)
  11. #28
    Aug 2010
    Hey All,
    After a quick call to the interstate head office, they have very kindly agreed to arrange the repairs. The rim will be replaced with a second hand one, and the rest will be new parts. Exciting times!
    Only bad thing is that the Kelly Safari TSR in that size is not in stock in Australia and there is a back log of orders, so could be a few MONTHS until they arrive! We're going to see if they can supply a similar part-worn tyre until the new tyre comes in.
    All in all, pretty happy
  12. The Following User Says Thank You to tracemul7 For This Useful Post:
    TPC (30th May 2014)
  13. #29
    .......... TPC's Avatar
    63 Post(s)
    Quote Originally Posted by tracemul7 View Post
    Hey All,
    Good to hear, it pays to persevere.
  14. #30
    brisbane
    Quote Originally Posted by Timbo15 View Post
    I've had steel rim come loose so its not just alloy
