Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Twin alternator
    If your in Melbourne the blokes at Piranha off road have an output compensator that can increase charge rate by 0.5 volts as well.
    Another option anyway...
    http://www.piranhaoffroad.com.au/news/index/article/27
    I read on this forum once that they are not a good idea? I can't remember why but the person said they are great for newer model Toyotas because their alternator output is so low but no good for our Patrols.
  2. #12
    Advanced elmo4eva's Avatar
    Dec 2013
    I wish theee could be a place here that could do it
  3. #13
    I was told our gq's are crap at low rpm's...lol
    Hence the increase at lower rpm needed.
  4. #14
    More and more vehicles are now running their Alternator Output thru the ECU. This allows them to lower the voltage which means less load and saves fuel and reduces emissions
    Quote Originally Posted by elmo4eva View Post
    There are any amount of them on Ebay, most are simply a diode in the Alternator sense fuse
    No alternator puts out anything like max power at low engine RPM's so it's not just GQ's and the only effective way to fix it is to increase the pulley ratio so the Alternator spins faster.
    The devices on Ebay et al for the "lower voltage" issues with new vehicles won't help. They don't increase the Alternator output per se just the voltage so they are more suitable for AGM and Calciium hybrid batteries
  5. The Following 3 Users Say Thank You to the evil twin For This Useful Post:
    AB (6th May 2014), MudRunnerTD (6th May 2014), Robo (7th May 2014)
  6. #15
    Oct 2011
    Essendon
    I alway run a loud sound system cause im partially deaf
    Must remember not to camp next to you......LOL
    I have decided to run a third big-arse AGM in an ArkPak battery box as another option. Just a few more things to do to wire it in the vehicle and with a Ctek DC-DC charger will give good solar capability at camp too.
    TB's suck for the piss-ant space they allow for the second battery under the hood.
    Sent from my iPhone using Forum Runner
