Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 79
Thread: Bent up Sill
    Apr 2013
    looks like the floor would be crimped also ?
    the one thing wrong with middle age ...is knowing you will grow out of it !
  2. #22
    Mar 2013
    Quote Originally Posted by menace 2 View Post
    Floor doesnt look crimpled, when the side step got bent yo is crushed the bottom sill and pushed the top of it up and in a little..
  3. #23
    Mar 2013
    How much would I be looking at for a replacement sil? and where would I begin looking around brisbane?
    I know how to weld..
  4. #24
    brisbane
    Mate I'd be trying to weld on the slide hammer if that fails then try the pop rivets and if all fails cut it out and weld in.
  5. #25
    Legendary happygu's Avatar
    Skid,
    You can get the sill from a wreckers .....if you tell them where from and where too, they will cut you out a piece..... if you do this, get it from the door jamb seam, to the underneath seam, to try and join it at the factory joins
    Just be aware, it is a fair job to cut and reweld ... not for the faint hearted, but if you have plenty of time have a go....
    Mic
  6. The Following User Says Thank You to happygu For This Useful Post:
    MudRunnerTD (15th April 2014)
  7. #26
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    Quote Originally Posted by SKID View Post
    This guys panel look nearlyas bad as mine, why is everyone saying make an insurance glaim? will cosy me 600 for the excess to start with.. rivits etc will cost alot less..
    Yours is a fair bit worse old mate, for starters the damage has effected the lower area of your B pillar, keep in mind, looking at the pics from the other thread, im pretty sure the damaged sill has NOT been returned to its "factory" shape on the inside or the outside, like I said in my post earlier "All this also depends on what the car is worth, and how "fixed" you need it ?" so if that is as good a repair as you need, why not just follow down the same path ?
  8. The Following User Says Thank You to 04OFF For This Useful Post:
    MudRunnerTD (16th April 2014)
  9. #27
    Mar 2013
    Quote Originally Posted by megatexture View Post
    As in weld the tip of the hammer to the sill? I've seen some pictures of using rivits and attaching slide hammer with vice grips to give more of a pull than just using pliers.. Any advice appreicated..
  10. #28
    Yeah so if you have a welder then just tack weld the end of the slide hammer to the sill or if you need to give it a lot of big hits then maybe weld something to the sill and a number of spots (chain links or something) that is suitable to hook the slide hammer to and get into it. When you finished your cutting the welds off rather than trying to bog holes drilled.
  11. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
    growler2058 (16th April 2014), megatexture (17th April 2014)
  12. #29
    Skid,
    If you can beg or borrow a panel beaters slide hammer, you need to remove the paint with a wire wheel, then spot weld the blind rivet ends in all the areas where you need to pull the panel, then attached the slide hammer to the rivets, and start pulling the panel in small sections at a time.
    When you are happy that you have the panel as close as possible to original, twist off the rivets, and start bogging away
    Without the right tools it is all about improvising
    Mic
  13. #30
    Mar 2013
    I dont want to stuff my slide hammer up for future use, what if I were to weld nuts to the sill and screw the hammer into them to do the pulling, then just break the nuts off when finished?
