Results 1 to 6 of 6
Thread: Rain leak
    Expert Rickie3's Avatar
    Jan 2014
    Rain leak
    Can anyone give me some pointers please, we have had a bit of rain down here in Tassi recently, As I havent had this GU long, bought during summer months! anyway after the rain I opened the car to find the deep rubber mat full of water, so I booked the patrol in for a brand new windscreen on Monday, I also had the rubber around the screen replaced! This morning after raining over night I thought I would go out and check, and sure enough there is a very small amount of water on the mat, so grabbed a torch, it appears to be dripping from the heater fan, this is rain water not coolant, has anyone else had this problem? can anyone recommend a good place to start to try and find this leak? I have a snorkel on the bus, and where it goes on the pillar has a single pop rivet and it is loose, is it possible water water could be running down the pillar into the cab any advice appreciated
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    Have a look at the tabs/seals where the wiper cowl attaches to to body, remove heater fan inside the car, and you can look straight up with a torch to see, bet this is the problem.
  3. The Following 2 Users Say Thank You to 04OFF For This Useful Post:
    MudRunnerTD (10th July 2014), Rickie3 (2nd April 2014)
    Jan 2014
    Quote Originally Posted by 04OFF View Post
    cheers for that, the cowl is also called a scuttle? I did have that off a couple weeks back and fitted new wiper control arms, I notice the scuttle sits in what looks like plastic type grommets, so what your saying these grommets could be leaking?, if so where would I purchase new ones to replace the lot? I hate water leaks
    Jan 2014
    Champion!!!!!! removed heater fan, and sure enough those clips are leaking, and there is one missing as well, where the heck would I get new clips from, but bloody oath thanks heaps for your help saved me days of hunting
  6. The Following User Says Thank You to Rickie3 For This Useful Post:
    Nissbits or Patrolapart if not Mr Nissan is your man I would think
  8. The Following User Says Thank You to threedogs For This Useful Post:
  9. #6
    178 Post(s)
    They are called Scrivets.
    http://www.nissanpatrol.com.au/forum...!!!!!!!!!!!!!-
    With the carpet wet you’ll need to take it all out to get it dry. It starts to smell after a while!
