Page 338 of 1057 FirstFirst ... 336337338339340 ... LastLast
Results 3,371 to 3,380 of 10566
  1. #3371
    22 Post(s)
    Quote Originally Posted by Drewboyaus View Post
    So not much then......
    Nope, considering the rest of the things I want to do
    96 GQ coil/Cab
    08 G6eT
  2. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    Drewboyaus (16th March 2014)
  3. #3372
    Expert meh's Avatar
    Nov 2012
    Regents Park, QLD
    Which one ?
    Edit: never mind just saw the super cheap ad
    Yep the 12000lb one :-)
  4. #3373
    Finally got off me butt and swapped the UHF and second battery over from the clunker into the new GQ, will eventually fit a switch so I can use either the 3db or 6db aerials depending on terrain.
  5. The Following User Says Thank You to Clunk For This Useful Post:
    Woof (16th March 2014)
  6. #3374
    Quote Originally Posted by meh View Post
    Got a winch on sale $479 50% off :-)
    Yeah I was thinking about grabbing one of those but didn't think the missus would have been too happy if I'd walked in the door with one of those instead of some food lol
  7. #3375
    .......... TPC's Avatar
    63 Post(s)
    Food is over rated.
  8. The Following 3 Users Say Thank You to TPC For This Useful Post:
    BigRAWesty (16th March 2014), Clunk (16th March 2014), Stropp (15th March 2014)
  9. #3376
    Treated the GU diff to some new bearings, seals and some DBA slotted rotors and bendix brake pads, all thats left now to do the swivel hubs, rebuild the calipers, brace it and swap it into the ute
    Attachment 41914
    What pads did you choose??
    Soft, hard, etc
  10. #3377
    wouldn't that interfere with reception,
    Dont you need to keep UHF antenna away from each other,
    All I do is screw on a small one for hilly drives and the longer one for hwy work
    I think you would lose reception
    what style switch would you use????
  11. #3378
    Don't see why it would intefere with reception seeing as it'll only be using one antenna at a time and they're set at 2 feet apart ...... wouldn't have thought it would be any differrent to some one running 2 radios, the switch I have is similar to this one http://www.ebay.com.au/itm/2-POSITIO...5357363&_uhb=1
    I also have the interchangeable antennas but once I've installed the switch I won't need to swap the whips anymore.
  12. #3379
    Advanced Fozzee63's Avatar
    Feb 2014
    Echuca
    Start of our preperation for trip away ..... Lots of wiring to sort out and tidy up, I think I need a lots more battery terminal connection points.
    And lots of tighning NUTS and bolts, pipes and fit a few p clamps to secure lots pipes .......
    Big trip in 11 weeks echuca to birdsville via tippaburra, innamincka via cordillio downs track to birdsville then a loop back to innamincka via walkers crossing track and a different track from innamincka home to echuca all with our 4x4 camper.
    So lots of prep
    DONT FORCE IT! ......Get a bigger hammer
  13. The Following 3 Users Say Thank You to Fozzee63 For This Useful Post:
    threedogs (16th March 2014), TPC (16th March 2014), Woof (16th March 2014)
  14. #3380
    Patrol God Stropp's Avatar
    38 Post(s)
    image.jpgimage.jpgWashed the troll and got rid of all the mud around the doors, I also finished cutting and fixing some rear window shades, she is cool now.
  15. The Following 5 Users Say Thank You to Stropp For This Useful Post:
    BigRAWesty (17th March 2014), Clunk (18th March 2014), rafa (26th March 2014), threedogs (17th March 2014), Woof (16th March 2014)
