Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 56
Thread: dawes and needle valve for common rail?
    As you have the gauges, block the EGR and monitor how it goes. Its not a big job to remove it if your not happy.
    the evil twin (1st February 2014)
  3. #12
    Jun 2013
    Central West NSW
    Thats me guys. Buy through here and 10% goes back into the forum. Which reminds me i need to transfer some coin across
    Hey Mudski, PM sent. This has been on my to do list, and I am about to do a service so now is as good a time as any.
    Lemo
    http://www.nissanpatrol.com.au/forums/image.php?type=sigpic&userid=16293&dateline=137569  2513
    2006 GU IV ST 3.0L TD Di
    Autron Boost and EGT, Dual Bat, Dawes & Needle Valves, ARB Alloy rack, more to come.
  4. #13
    What mudski said...
  5. #14
    I have had a dawes and needle setup on mine for about two years now, with no ill effects. The ecu does a good job on an unmodifed car. But with a rail chip with no boost control, the egts can get to high. The dawes is a good way to bring egts down and gain performance when adding more fuel.
  6. #15
    Patrol Guru rottodiver's Avatar
    Nov 2011
    Perth
    I had a Dawes and needle valve, took me a bit to install it( a lot of help from here but very very simple once you know how...maybe a 2 minute job once all hoses are cut) I have since removed them( on the side of the road on a trip) I really had troubles Setting them correctly.. They ran well in the city then when towing on the hwy I hit limp mode twice when trying to overtake on a hill. I haven't put them back in because I have had no over boosting problems at all... Although the faster spool up rate was very noticeable. I have the egr blocked with no hole in it , 3 inch exhaust, provent catch can, and chip. Have had the check engine light 3 times only(easy fix with scan guage)
    Scotty
  7. The Following User Says Thank You to rottodiver For This Useful Post:
    growler2058 (27th November 2020)
  8. #16
    Apr 2013
    Mount Nasura
    I run a CRD with the EGR block, Provent and Scanguage, no massive spikes in boost, runs well.
    Mine has EGR block and no Dawes or Needle valve.
    I fitted the EGR then adjusted the VNT as per Chaz's bible and she's been tickety boo ever since (chipped, 3" exhaust, EGR block, pyro and scan gauge)
    I bought the Dawes gear but it runs perfectly well on the ECU so never bothered so I sold the bits
    Where can I lay my hands on this bible ET??
    2008 GU ST Bog stock and no smoking barrels!
  9. #17
    @ RD What do you think was the cause of the limp mode,
    dawes adjusted correctly should have limited your boost to 15psi max,
    with no chance to overboost
  10. #18
    Nov 2011
    Perth
    I was under the impression about 18 psi was ok for crd,s
    It can only have been it was set too high, frustrating thing was it worked perfect ( so I thought) around town for a few weeks before the trip. It even triggered the engine light with the over boost code... I guess I am more comfortable with the ecu looking after the boost than me setting it.. If it was to over boost with out the valves I would think about re installing them but I have had absolutely no problems since taking them out..( do miss the faster spool up though... It really does improve with it). As it is I am happy with egt,s , boost, Engine temp and also auto trans temp, even the boost doesn't fluctuate too badly either so will see how they go..
    Scotty
  11. #19
    I believe the Cr ECU handles the boost issues a better than the Di.
    So you have a dawes set up for sale lol
  12. #20
    Nov 2011
    Perth
    Nah not for sale... I am not against having another go later... Maybe during simpson when there are some people around me that know what they are doing ( a lot more so that I) it is now plug and play, all hoses are at length etc
