Results 1 to 10 of 18
Thread: How do you look after cast iron cookware
    Thomastown, Melbourne
    6 Post(s)
    As above what are the correct ways or personal experiences with looking after all my cooking gear??
    Thanks in advance for all the informative replies with little or no crapping on!!!! he he!!
    476 Post(s)
    Make sure its clean and dry firstly. Then what i do is coat the inside with some olive oil so it wont rust. Then wrap it up in large back ans seal it up so no dirt os dust gets in and sticks to the oil.
    Bloodyaussie (29th January 2014)
    You Cook??? Bahahahahahaha
    Like mudski I wash mine when I'm finished, but don't use soap. Then rub the inside and outside with oil and put it over heat for about 5 mins. Never do it when I'm away though but when I get home
  6. The Following User Says Thank You to Winnie For This Useful Post:
    476 Post(s)
    Same here. No soap and dry it over heat.
    Expert Steve4wdin's Avatar
    Feb 2012
    Western Sydney
    For my camp oven, I generally stick it back on the heat with some soapy water, bring back to the boil for a few minutes, tip out the crap, than scrub clean. Rinse with fresh water. Put back on heat and wipe out with paper towel. When dry, like the other guys, lite coat of cooking oil. put away all good till next time. Takes 10 min may be a VB or 2, hey Winnie
  9. The Following User Says Thank You to Steve4wdin For This Useful Post:
  10. #7
    Feb 2012
    "Hiding Under Your Bed!"
    30 Post(s)
    Best oil to use to prime / re prime cast iron is linseed oil.
    The outside of my camp oven is sprayed with a high temp engine black paint which protects it and doesn't affect cooking temps.
    If your camp oven stinks or has a burnt smell to it, cook the the crappy, fatty bacon bits in it and then empty it and use the bacon fat to oil the inside of the oven.
    Never use any citrus based cleaners.
    Best site to read up on seasoning cast iron is -
    www.aussiecampovenforum.com
    www.swat4x4.com
  11. The Following 2 Users Say Thank You to oncedisturbed For This Useful Post:
    Bloodyaussie (29th January 2014), MudRunnerTD (30th January 2014)
  12. #8
    .......... TPC's Avatar
    63 Post(s)
    Same as mudski and winnie said but I always do it while away so I don't forget when I get home.
  13. #9
    Feb 2011
    Shed
    45 Post(s)
    Ask AB.................I mean DONT ask AB
  14. The Following User Says Thank You to growler2058 For This Useful Post:
  15. #10
    6 Post(s)
    You idiot! !!!
    Thanks guys for the many responses.
  16. The Following 2 Users Say Thank You to Bloodyaussie For This Useful Post:
    BigRAWesty (29th January 2014), fracster (29th January 2014)
