Results 1 to 9 of 9
Thread: GU Sub-Tank on a diesel.
Threaded View
  1. #9
    Oct 2010
    Old Bar, NSW
    Terry on the ute I have this is what happens.... if you have a look in the main tank filler tube there is a flow of fuel from the sub when "self priming", doesn't flow for long.
    If you can see that it is a good start, then try turning the transfer pump on and the flow should be seen in the same pipes.
    My transfer runs at about 1 litre per minute, it is slow.
    Hope you find it is all good on yours
    Macca
  2. The Following User Says Thank You to macca For This Useful Post:
    terreyhills9 (9th January 2014)
