Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Intercooler Upgrades zd30 EBAY
    Expert Limmy's Avatar
    Hi Guys
    I'm looking at probably upgrading my intercooler to the welded ones. I've seen now a couple of sellers advertising these intercoolers. And they don't need Exchange units either. They are all over ebay under $400 .
    Some talk about having 20 tubes instead of 12 making it better ? thicker core ?
    Anyone purchased any of these. which ones are recommended ? are they good ?
    thanks heaps
    http://www.ebay.com.au/itm/NISSAN-GU...ht_1080wt_1292
    http://www.ebay.com.au/itm/BRAND-NEW...ht_1276wt_1292
    http://www.ebay.com.au/itm/NEW-NISSA...#ht_670wt_1054
    They have come down in price and rightly so for them to be charging $600 PLUS FOR A $50 CORE is ridiculas
    Check if they are pressure tested , the higher the better and what kind of warranty they offer.
    I paid these prices for a change over but I was happy with that. None of these were available 6 months ago
    Its a must do and you will notice the difference
  3. The Following User Says Thank You to threedogs For This Useful Post:
    Limmy (4th January 2014)
    The first link looks alrite. comes with O-ring . and 5 year warranty . I will ask them if they are pressure tested thanks TD
    offer them $350 that's seems a fair price in my books, good luck
    All those IC's you linked are the same IC, just from a different reseller. I got one from Autocooling for $380. No improvement in power, EGT's dropped but only ever so slightly, maybe 10-30c, but my EGT's were low to start with. Would I have bought one if I knew the little difference I would have in EGT's? Nup. But I sure as hell wasn't going to hand over my hard earned on a CC or HPD cooler, thats for sure. Unless I could try one first, then I would.
    Being all the same, go for the one that gives you the new o'ring I reckon. I just used my old one and sealed it up with a smear of silicone.
    One thing I did find though. The hole where the MAP sensor screws into, the taper they put on it wasn't big enough so the sensor didn't pull down properly. I just drilled it out a little more and then more silicone there too, just to make sure it won't leak.
    Anyway one less thing to worry about, they should have been tigged from the factory.
    Keep an eye on your gauges as you'll need to adjust your boost again.
    @ Mudski you mean the boost sensor
    Thanks guys . I'll probably get one. my intercooler is probably leaking anwyays - dirty and greasy . as for boost sensor . i've got the adapter for boost gauge . i willl smear some silicone ( good idea - i should've done that ) .
  10. #8
    5 min job only need a 10mm mini max and 8mm for the hose clamps from memory .
    check hoses for splits etc, as you said yours is oily good chance its stuffed
  11. #9
    Just ordered one of these to replace my oily leaking original 03 troll.
    I'd rather ease off the go pedal to reduce egt's than try to get more blood out of the zd stone with the you beaut big $$$$ coolers
    Waza
  12. #10
    Yeah boost sensor...
