Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 59
Thread: Zd30 squeal
    Expert dirtygu's Avatar
    Naire, South Australia
    How do I get it out of limp mode I know my egr is stuffed but I have that blocked off and its been like that for the last 1500km its only been in " limp mode " since wensday
  2. #22
    Try disconnecting the battery as TD suggested. Do you have a dawes valve fitted?
  3. #23
    Nuh have not fitted the dawes yet
  4. #24
    You'll need to fit the NADS set up to limit your boost.
    Whats yours again, 15psi tops for a Di diesel
    PM Mudski for what you need,
    after you disconnect the battery it may be ok until you floor it and it'll go into limp mode again
    until you can control the boost
  5. #25
    I did hit 18psi last night on about quarter throttle lol I just reconected the battery and wiped the codes took it for a drive the only code that keeps comming up it 1003 whats that ????
  6. #26
    Ok found out 1003 is egr would that make me loose power if its blocked off
  7. #27
    I think its showing that BECAUSE its blocked, and not working
    That's my take on it. sounds feasible eh
    You don't need big boost on these Di motors 15 psi tops with
    the peak spike to 20 psi now and again
  8. #28
    But would that code make the engine not run properly
  9. #29
    yes would be my answer but Yendor would be able to tell you for sure,
    when mine went into limp mode it was my CPS showing the error don't know why.
    plus a real PITA to change as well. fitted NADS {Boots} and haven't looked back since
    it going like a bought one. LOL
  10. #30
    So should I change egr or get rest of my nads done or take out the blanking plate
