Results 1 to 10 of 17
Thread: Help in understanding my dual tank setup
    Expert Flo-w's Avatar
    G'day
    I've bought a "new" GQ a while ago and I find it a bit difficult to work out how the dual tank setup works. I can't ask the previous owner as I bought it from a dealer who bought it from a middle man who bought it from another dealer. There's nada documentation about it.
    My mechanic had a quick look and says there's my standard 90l tank and a 75l sub-tank. There's only one filler. There are two hoses going from that filler to the tanks. We figured out that there's a switch (on/off) which starts a pump in the sub-tank. There's also a light which comes on when that pump is going. At that point all seemed clear: once I can't get any more fuel in I've 165l with both tanks filled. I drive on my main tank and when the fuel light comes on I activate the pump. There should now be enough space in the main tank to empty my sub-tank. That's the theory.
    In practice I filled up twice so far. First time after the fuel light was on for maybe 30km I got 82l in (gauge showed full afterwards). I didn't pump fuel over back then as I didn't yet know how the whole setup works.
    The second time I filled up I got 95l in. Now that's more than the main tank so I reckon something must have gone in the sub-tank. In fact I assumed that both tanks had to be full at this stage as I didn't get any more fuel in.
    Now that I tested the fuel pump with an half empty main tank it first seemed to pump for maybe 30 seconds (light is on and I can hear it work). Then it started to sound different and the light started flashing.
    What's going on here? If my sub-tank is full why does it not pump it over?
    If my sub tank was almost empty then how do I fill it??
    Any ideas anyone?
    '93 GQ 4.2l diesel: 3" Koni/King lift, 33" Mickey Thompson ATZ P3, 165l tanks, snorkel, roof rack, rooftop tent, CB radio, DIY storage, dual battery setup, & 50l Waeco fridge.
    RIP '95 GQ 4.2l petrol/lpg, RIP '89 Pajero
    Yendor or Growler may be who you seek
    Would definitely need Growler or Yendor or someone rather than me..lol...But I'll have a guess.
    You would most likely have a T piece half way down your main filler neck which would go into your aux tank, when main tank is full it would start to fill aux tank. Not an ideal set up but works.
    Do you get a lot of splash back when filling up with fuel?
    To me that sounds like the aux tank running dry or a blockage in the pump/lines and the light flashing is a sensor alarm notifying you.
    If your 100% sure the sub tank was full then someone else needs to help here but from what you described sounds like the pump running dry.
    As above, they normally fill when the main is full and the overflow goes into the aux through the T piece on the main neck. They can also be plumbed to get similar fuel at the same time when filling too.
    Hopefully some more solid advice will come soon...lol
  4. The Following User Says Thank You to AB For This Useful Post:
    Flo-w (13th December 2013)
    Feb 2011
    Shed
    45 Post(s)
    NFI sorry mate I've just got one small shitty tank
    Boo hoo last time I nominate you, geeesh
    Thanks AB. Looks like I need to try and fill up again.
    I do get some splash. In some stations I need to turn the nozzle so that it doesn't stop all the time.
    It really is a bit of a weird setup if it only has a T-piece. You can always only guess how much is left in your main tank in case you don't want to fill the aux tank as well. And to make sure they're both full you need to overfill I reckon.
    Makes you wonder why not just put 2 fillers and two gauges in and have a switch to go from one to the other. $$ I guess.
    Quote Originally Posted by Flo-w View Post
    The proper dual necks are expensive that's probably why the bloke just tapped in to the main.
    I'm currently putting an aux in mine and just spent over 100 on this puppy but I think it's worth it.
    If your keen in getting one then click on the parts link at the top of the page and you should find one at a Patrolapart.
    I wonder if they have grabbed a gu setup as they pump a little Fuel over each start up to prime / check the pump.
    Could be your usage issue.
    I think the is only one way to check your setup, start chasing fuel lines and and wiring..
    Could be a cheap dual valve setup or an expensive 6 port valve..
    You'll need to find out to understand it..
    OK, tried again. The fuel gauge read half full (on a 90l tank) and my GF got 77l in before she got tired of it. That tells me that some of it went into the sub tank.
    It looks like the fuel pump/line is blocked though as the pump makes a very tired noise and the red light keeps flashing.
    Looks like I drive up to 75l of dead fuel around now. No time to get it fixed before Xmas. At least I won't need it in the high country as much as elsewhere.
  11. #10
    Yep when you get a chance get underneath first and check the lines.
    You should also have a filter before the transfer pump so check that first. Could be definitely blocked.
