Page 287 of 1057 FirstFirst ... 285286287288289 ... LastLast
Results 2,861 to 2,870 of 10566
  1. #2861
    Advanced bear3103's Avatar
    Apr 2013
    Will be fitting second battery tray to mine shortly
  2. #2862
    bought a new windscreen washer bottle and motors as mine has disintegrated, so should arrive before next weekend, finally got fed up after 3 years of squirting a water bottle out of the window in order to clean the windscreen
  3. The Following 2 Users Say Thank You to Clunk For This Useful Post:
    Drewboyaus (18th November 2013), Stropp (16th November 2013)
  4. #2863
    Expert AJTich's Avatar
    Oct 2013
    Andrews Farm
    Thanks Cam.
    Mine on the other hand came with the two points, four 3/4 bolts with foprives ur smaller bolts, and the two captives with the wire..
    AJTich
    2004 GUIII, white ST, 3.0L manual wagon, NADS,EGT/Boost,Water Temp/Oil Press gauges, drawers, UHF, stubby cooler on the 4WD selector...
    "I don't get bogged, I have unplanned 4WD training activities..."
  5. #2864
    @ Trekster how bad is it, totalled, I think RACV down here say car/4x4 is UN RW with hail marks all over it.
    Personally I cant see why, hope its repairable at least
  6. #2865
    Feb 2011
    Shed
    45 Post(s)
    Did more to my custom "bar by growler" by triangulating for strength.
    Aaaannnnnd put some new stickers On Cheers Lucas
  7. The Following User Says Thank You to growler2058 For This Useful Post:
    taslucas (17th November 2013)
  8. #2866
    Feb 2011
    Shed
    45 Post(s)
  9. #2867
    Should strengthen it some what ,,,,,,,,,,,,,are the ends enclosed???
  10. #2868
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    So you want me to start working on a few sticker designs for "bar by growler".
    Hello from Under Down Under!
  11. #2869
    Feb 2011
    Shed
    45 Post(s)
    HAhahAHHAHAHAHAHA yup sounds good, but can you keep it clean hahahahahaa
  12. #2870
    177 Post(s)
    Completely gutted the rear end, cleaned up mud and crap stuck between the chassis and rear bumper area. Probably about 10kg of s*** came out.
    Tidied up tow bar cabling with new plug etc... and install the tow bar while I was at it !!! I also took photos of step by step tow bar install, and I'm considering a small write up on it that may help some in the future, as I was in the same boat a while back!
    Now kickin' back with a few nice cold stubbies!
  13. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    BigRAWesty (17th November 2013), Bloodyaussie (17th November 2013)
