Page 8 of 12 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 113
Thread: Car Fridges , help with some stupid questions please
  1. #71
    Expert Shaun 4x4's Avatar
    Secrets
    Quote Originally Posted by firm351 View Post
    Do you know any good sparkys mate lol
    Yer I know one in particular. Lol
  2. #72
    Feb 2012
    Make sure the polarity is correct at the 12v outlet otherwise it won't run
  3. #73
    Secrets
    Quote Originally Posted by ben ren View Post
    Yer no shit. lol
  4. The Following User Says Thank You to Shaun 4x4 For This Useful Post:
    BigRAWesty (14th November 2013)
  5. #74
    Hay mate. Mind popping over to the intros. Just something we ask all members.
    Feb 2012
    Yeah will do.
    Sounds like crap but happens more than you'd think
  7. #76
    Yeah will do.
    Fair enough..
    Expert Warwick89's Avatar
    Oct 2013
    Cairns
    I've got a CFX65 and haven't had a problem with it, on the move over from cairns at the start of the year I was running it for days just on an arkpak.
  9. #78
    Feb 2012
    I've got the cfx50,got it when they first came out.
    No problems so far,the basket makes it easy to fill,just load it up in the kitchen then drop it into the fridge.
    I think a cover is on the cards as it's showing a few marks
  10. The Following User Says Thank You to ben ren For This Useful Post:
    04OFF (14th November 2013)
  11. #79
    Hardcore 04OFF's Avatar
    Brisbane,QLD
    12 Post(s)
    Thanks ben, good idea about always removing the basket to fill the fridge.
    I picked up a Waeco CFX-40 today, with a bag and wireless display for $926, too good a deal to pass.
    It all fits into the back of a GU Wagon perfectly, even lines up so well with factory mounting points , i can secure the fridge with just one ratchet strap.
    The fan vents are in the ideal spot, as is the power cord angle, the MP3 pocket at the front is just perfect for a bottle opener
    The whole unit sits below the window line, so visibility does not change from inside the car, outside the car, the fridge display is high enough, you can read the fridge temp looking through the rear barn door window.
    The fridge door just clears the roof , with the bag on, the bag door flap will just hit the roof when extended fully vertical, it works great as a door stay if you push it up high enough.
    Im testing the fridge now, its night time and raining, so not exactly a good test, but so far it seems pretty good in all other aspects.
  12. The Following User Says Thank You to 04OFF For This Useful Post:
    gaddy (15th November 2013)
  13. #80
    Brisbane,QLD
    12 Post(s)
    You guys that own fridges, do you turn them on a few hours before you need them, or run it overnight ?
    And do you only fill with stuff that is already cold ?
    Or does anyone just put hot stuff in a hot fridge, and start driving ?
    Also, what temp do you guys set the fridge to run at, do you set them colder to start with, then up the thermostat to not freeze everything ?
