Results 41 to 45 of 45
Thread: Question on winches
  1. #41
    Western suburbs of Melbourne
    12 Post(s)
    Quote Originally Posted by nipagu7 View Post
    hi guys .
    I bought the runva 11000 xp . I think it will be the only runva that will fit as I only have 27mm of clearance between the winch motor and the chassis . I have a 2011 gu7 with arb steel bar . I checked the specs for the other runva's but the motors were longer and not able to be fitted to my car .
    I can tell you now that the Runva EWX12000 will fit on an ARB deluxe steel winch bar.
  2. The Following User Says Thank You to MEGOMONSTER For This Useful Post:
    cgm (13th September 2013)
  3. #42
    12 Post(s)
  4. #43
    Surprised you went steel wire rope Mick, make sure you consider that when you organise your front springs when you do the lift mate. There is an extra 15kgs probably in that wire rope. Also make sure you buy at least 1 winch dampened, 2 would be better.
  5. #44
    Oct 2011
    Essendon
    I thought you went for the Dyneema......
    Tip tip tip......tap tap tap....
  6. #45
    12 Post(s)
    I did go dyneema but the spastics sent me a wire winch with the rope and hawse separate. They still need to change it over.
    So I'll have a cable for sale soon.
    ARB are giving me a dampener.
