Page 3 of 11 FirstFirst 12345 ... LastLast
Results 21 to 30 of 104
Thread: Portable air compressors
    Legendary 93patrol's Avatar
    Dec 2012
    Bunbury
    Make sure you use thread locker on stauns otherwise they move and can deflate your tyre completely also if sand driving make sure they are fully down as sand can get in the deflator and stuff it
  2. The Following User Says Thank You to 93patrol For This Useful Post:
    MEGOMONSTER (3rd September 2013)
  3. #22
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    @ winnie link only went to sunglasses,
    Went to a compressor for me?
    Hello from Under Down Under!
  4. The Following User Says Thank You to taslucas For This Useful Post:
  5. #23
    May have changed it, no big deal summer coming up
  6. The Following User Says Thank You to threedogs For This Useful Post:
  7. #24
    I'll put up some pics soon AIR on BOARD costs around $390 and the fitting kit a bit more.
    It'll take almost a day to fit as well. Have you thought about fitting a hot dog size tank
    on the LH chassis rail for you locker, If I can find a spot Ill mount the tank/motor internally
    for Locker and Train horn, the red tank will aid in tyre inflation via my BIG black PUMP
  8. The Following User Says Thank You to threedogs For This Useful Post:
  9. #25
    Aug 2011
    North West Tas
    56 Post(s)
    Don't think he needs one for a locker
    For the time being it will be n just to air up, then get endless air like you said.
    I'll be probably getting E-locker so won't need air for that.
  10. The Following 2 Users Say Thank You to taslucas For This Useful Post:
    MEGOMONSTER (3rd September 2013), Winnie (3rd September 2013)
  11. #26
    way overkill but boy do they work well,
    Roothy used to advertise a SCUBA tank full of compressed air,
    good enough to fill well over 4 big 4x4 tyres
  12. The Following User Says Thank You to threedogs For This Useful Post:
  13. #27
    Advanced Woodsta1704's Avatar
    Jun 2013
    Perth WA
    I've got the Bushranger Black Max! Its a great pump and hasn't let me down, fills a 33" tyre from 16psi to 38psi in just over a minute. I also use the Staun deflators and I also have an ARB deflator as well just in case I need to go to a lower pressure or a higher pressure depending on the terrain.
    Check out the link below.
    http://www.ebay.com.au/itm/BUSHRANGE...84a6498&_uhb=1
    2002 GU 3 Lt Patrol Wagon. On Board Air, ARB Front Air Locker, 2"Tough Dog Lift, Rear Air Bags, Tracklander Roof Rack, IPF HID Spotties, K&N Air Filter, Cargo Barrier, 3" Dominator Exhaust, Titan Drawers and much more.
  14. The Following User Says Thank You to Woodsta1704 For This Useful Post:
  15. #28
    Expert Ronin's Avatar
    Brissy
    4wd mag had done a comparison of compressors. it can be found here http://www.4wdaction.com.au/sites/de...RE%20air_2.pdf
    also dont forget to check the Duty Cycle as well, its a good indicator of the quality.
    2012 GU Patrol Simpson Edition. Auto. UHF, Bull Bar, 2" lift with Koni shocks, dobinson coils. 3" stainless Steel Exhaust.
  16. The Following User Says Thank You to Ronin For This Useful Post:
  17. #29
    Western suburbs of Melbourne
    11 Post(s)
    Quote Originally Posted by Ronin View Post
    Problem is many don't give you all the info you want. They just tell you the bits they want.
  18. #30
    Duty cycle should be on the label on compressor or on the box it came in.
    Might even have a user manual to check
  19. The Following User Says Thank You to threedogs For This Useful Post:
