Results 1 to 10 of 1132
Thread: 23 - 24 - 25th August - VICTORIAN MEMBERS MEETUP at Licola/Dargo
Threaded View
    This maybe your gearbox issue you wrote about not long ago.
    Would be interested in what it is hopefully not too painful.
    Know what you mean about a daily driver, you do limit yourself to how hard you go,
    and where you take it, that's for sure
    Nah def not anything to do with the gearbox. It kinda feels like its loosing vacuum and at low revs its almost a two foot job to depress the clutch. I'm going to try to bleed it. Try. Last time it wouldn't bleed at all. Checked all vac lines and they are all spot on. I might just order a new slave cylinder and change it over while I'm at it.
    Found the horrible noise under the bonnet. The idler bearing was as dry as a witches tit. removed all and I'll lube it up tonight.
    Anyone got pics of andy taking the deep option on the river crossing of Friday?
    Roofy, Your a tease mate. Stopped in Licola for a dump and air up the tyres and I was soooo tempted to turn around. But I'm sorta glad I came home as I washed my car, (used 600litres to wash the car and 100'ish to clean the gutters in my street. All tank water I used so I went troppo with the hose.) and found and half fixed one of two issues.
