Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 53
Thread: Are bigger tyres really worth it???
    Nov 2012
    Bayswater, Melbourne VIC
    Wow thanks guys. Lots of good advice there. Gives me a lot to think about. I'll post some pics when I finally decide
  2. #12
    285/75 R16 is the perfect tyre for most off road situations, touring or hill climbing. If that is your thing then a 33 or 285 is perfect, if mud is your thing then 35s and up i where its at these days or bring a winch and a good battery and plenty of time and patience.
  3. #13
    Expert Squalo's Avatar
    Sunshine Coast
    33" tyres give a smoother ride than smaller diameter (basically the larger the diameter the smoother the ride), as they tend to roll over bumps rather than be slowed or deflected by them. The extra weight also helps with the ride, although you should have the suspension upgraded because the force of a 33" being deflected up puts a lot more load through the shock and spring.
    When you drop pressures for sand or rock they also bag out better, and it's not the sidewall bagging that helps - it's the north-south increase in the amount of tread on the ground that makes the difference.
    Downsides are as mentioned greater wear and tear on the vehicle (brakes work harder, suspension bushes etc. work harder), reduced fuel economy, potential speedo error, and changing a tyre becomes that much harder due to the weight (and they are heavy!). You might also consider how your spare will be carried - will a bigger tyre fit? - and whether you can get a replacement tyre or two in places that you might want to travel.
    Also, if you have friends that you will definitely be travelling with, it is nice to have some compatibility with wheel/tyre size in case of serious tyre issues, and you might also consider the same aspect with regard to the tyres on the trailers, if any.
    Personally I think they are worth the money, in fact I think a modern Mud Terrain is always the way to go - a lot of brands/models of MT are very good on tarmac now - the BFG KM2s are better than many, or even most ATs when it comes to wet tarmac grip. And whenever you go offroad you know you have maximum traction.
    1995 GQ TD42 NA
  4. The Following User Says Thank You to Squalo For This Useful Post:
    threedogs (13th August 2013)
  5. #14
    Jul 2013
    tyres are everything. when i bought my patrol it had 35" all terrains.
    tyres were brand new, but all terrains. i got left behind by a hilux on 33" muddies. since then i have switched to 35" BFG KM2's and havnt gotton stuck. your uncle doesnt know what he is on about saying a 31" muddie will take you anywhere. ill go further in just rear wheel drive on 35's then you will on 31's
  6. #15
    Bit harsh as it was an honest question, not every one can or will fit 35" which I believe deem any 4x4 un RW.
    Can you also jump over to the intros and let us know a bit about you and you're 4x4. just something the forum asks of us all.
    BTW a Navara in the right hands on 31"s will be on par with a Patrol on 35"s in the wrong hands IMO
    Rustyboner81 (13th August 2013)
  8. #16
    Expert oddkid82's Avatar
    Apr 2013
    I agree, I have had a d40 on 31 all terrains and got to most places without any trouble. I just chose the right tyre pressures and picked the right lines.
  9. The Following User Says Thank You to oddkid82 For This Useful Post:
  10. #17
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Quote Originally Posted by oddkid82 View Post
    Depends where you drive though really. One persons idea of 4wding may not be as hectic as anothers.
    Hello from Under Down Under!
  11. #18
    Apr 2013
    That's true, I agree that bigger tyres give you a better chance of not getting bogged and taking harder tracks, without diffing out.
  12. #19
    I Like big Tyres,
    and i dont know why?
    something i cannot deny,
    Go Large! You know you want to!. Is Big Is Good!
  13. The Following 3 Users Say Thank You to MudRunnerTD For This Useful Post:
    BigRAWesty (13th August 2013), Drewboyaus (13th August 2013), Evo (18th August 2013)
  14. #20
    X2 first up intro..
    And my GQ has been running 31 road tyres for years.. I've followed turbo'd cars with 35's the whole time. You gotta drive to the conditions.. Know your cars limits as you'll go anywhere..
