Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Road tyre pressure?
    Beginner LocknLoad's Avatar
    Jul 2013
    Perth WA
    Thanks all. Yes they were cold pressures. I was back at the dealer today re some other small issues and discussed with the service manager. Agreed they were to high and recommended 40 as per most suggestions here. That's where they're at now. Cheers.
    2013 GU9 Patrol Value Pack (stock)
  2. #12
    Aug 2013
    I run 230 Kpa (33 psi) on my Pirelli Scorpions 265/75/R16. I gather from this thread that they are under inflated. Very interesting!
  3. #13
    33 is not bad. I'm not sure of the amount of k's you do in Botswana but here in Aus most do a good 100+ kilometres just to get to tracks. So to preserve fuel.... Lol
  4. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Safari Njema (9th August 2013)
  5. #14
    40 is at the top end for a empty Patrol you may find 36 front and 38 rear more comfortable around town,
    but hwy for fuel economy I run 40psi. So you have 35 to 40 to find your sweet spot. Check tyre pressures atleast
    once every two weeks.
  6. The Following User Says Thank You to threedogs For This Useful Post:
  7. #15
    cairns
    Hey locknload b careful with those bridgestone duellers the side wall is rubbish and I had the tread peel on two of mine running 38 psi on a gravel road .I googled them and a lot of other people with same trouble so I switched over to bfg ats as mine is a work ute and time is money as they say . The duellers had only done 5000 klms so tyre place gave me $110 each for the three good tyres . Luckily a pal gave me a lend of one of his split rims before trip or I would have been walking.
    2012 gu6 dx canopy factory snorkel and bull bar new bfg all terrain, bellow style air bags, uhf, centre console, tinted windows, projecta 150 amp dual battery set up ipf super rally spotties, nitro oil shocks
  8. #16
    Quote Originally Posted by alfonso View Post
    Now that's interesting. My old's ran desert duellers for 20 years.. Got 50 thou out of a set easy, and never an issue.. Ran 38psi with a mix of dirt and blacktop (more bitumen) but yea, never an issue..
    cairns
    maybe I got a bad batch westy but once bitten twice shy.
  10. #18
    Weirder things have happened..
    Oct 2013
    Perth
    I like 32 psi front and rear , more in the back if towing or loaded up
  12. #20
    177 Post(s)
    Depends on vehicle weight. At close to 4 tonne when fully loaded I run 38psi front & 50psi rear. In it's everyday partially loaded state 38psi front & 46psi rear. 265/75 16 bridgestone d697’s.
    Cuppa
