Qatar Hmmmm!
Are you running Siam sand tires?
Qatar Hmmmm!
Steve
2011 Patrol Safari 4.8 (Fitek)
I would have thought you had a viscous coupling hub on your 4x4 fan.
The fan shouldn't be fixed, do you have a shroud on radiator??.
Maybe someone fitted a fixed Steel 6 blade fan, very noisy option.
will see what pics reveal first. But fans very noisy.
Pretty much - they're only good for inflating to 60 PSI and doing burn outs. Actually at 60 PSI, they offer almost zero rolling resistance so they're good for driving fast on road, but the handling is pretty bad. Especially when they're cold - wobble like crazy.
I would never fit them
Steve
sugu (19th May 2013)
If you use an underbody coating, make sure not to get it too close to heat from the exhaust system.
I have stripped the inside and applied Dynamat Extreme throughout entire floor pan/ firewall as far as possible. Frustrating job but great results
