Results 11 to 20 of 48
Thread: turbo lag / black smoke / no power
    Hardcore macca86's Avatar
    Jun 2011
    Brisbane again! whoo!
    Degreaser petrol kerosene just make sure its dry befor you install it
    Such is the rule of honour.
  2. #12
    Expert dirtygu's Avatar
    Naire, South Australia
    Really need to NADS your 4x4 asap
    fit boost and EGT guages, block EGR.
    fit manual boost controller and needle valve.
    remove clean and check IC for leaks
    As suggested clean MAF check all vacuum and turbo hoses
    replace any split or perished ones
    Do you know if Chip is fitted????
    ok first of all im still new so whats NADS ???
    second it has a bvoost gauge im working on the egt one
    how do you test the ic for leaks
    and isnt the boost contoller and needle valve the same
    and no it does not have a chip fitted
    cheers Anthony
  3. #13
    Expert WYLD333's Avatar
    Nov 2012
    Pakenham
    Start the car and give it a bit of gas and feel around the intercooler, you'll soon find where the leak is.
    If its a big leak you will notice you'll prob b droping boost on your gauge aswel.
    As for the hoses mate have a good lock around and you'll soon spot if something doesnt look right and you will also hear a hissing noise whisle driving
  4. #14
    By NADDING your GU you control the boost, best thing ever.
    you'll never overboost ,the needle valve will control spool up rate
    different to Dawes valve. Pop Mudski a PM for pricing on all the bits
    required, including EGR block. Then once guages fitted you'll see whats happening
    instead of guessing, Plenty written on this subject, search Chaz yellowfoot [guru]
    Great peace of mind for any Direct injection zd30
  5. #15
    476 Post(s)
    Quote Originally Posted by dirtygu View Post
    and yeas i can hear a noise sounds like a leak its coming from behind the engine possable egr pipe ????
    Remove all the IC hoses and check for leaks. Being over 10 years old no doubt the IC hoses will be worse for wear.
    If your IC is leaking you will see it. Check the top of the engine for oil deosits and check the under side of the IC for oily patches. Number one visual give away of a leaking cooler. If its the EGR, usually, it will give off a squeal when the engine warms up. Like I said, usually. Some have mistaken the EGR leaking for a belt squeal.
  6. #16
    Cheers mudski yeah its squeeling coming from exhaust manifold no 4 cay i just put the car in today the get compression test done as my mech has a gu4 and he thinks mine is only running on 3 i hope not
  7. #17
    Any news from the mechanics yet ??
  8. #18
    476 Post(s)
    I got my money on a warped EGR pipe if its squealing. Actually, which side of the engine?
  9. #19
    Its on the turbo side mudski no 4 cyl exhaust gasket at the top
    Ok got car back compression reads as this. 1) 400 (2)400 (3)100 (4)50
    They think its just valve adjustment i took it to hi tech diesel
    So yeah now i dont know what to do
  10. #20
    Legendary happygu's Avatar
    Don't want to be the bringer of bad news but no compression on 3 and 4 doesn't look good for the pistons, especially since it is an early 3 litre ......
    Mic
