Page 9 of 10 FirstFirst ... 78910 LastLast
Results 81 to 90 of 94
Thread: Lemon or not
  1. #81
    sunshinecoast
    hi , just read thru this thread and maybe i missed it , but have you changed your fuel filter . also some carby's have a small screen filter where the fuel line attaches to the carby . next i would clean the carby as it does sound like a fuel problem .
  2. #82
    ckh
    Guest
    Quote Originally Posted by nipagu7 View Post
    carby is fine just torque converter lockup and getting into diag mode on trannsmission the issue now....
  3. #83
    ckh
    Guest
    Quote Originally Posted by happygtu View Post
    Don't let any of your dodgy 'mates' near it.......
    s you recon keep it?
  4. #84
    Legendary happygu's Avatar
    I would....car looks great to me and to a lot of others here too.
    You are never going to buy a car that has no issues ever...it doesn't happen,
    and who is to say that if you get another car, that it won't have problems to fix as well.
    I will also add, that Patrols generally have less issues than other vehicles, so once you fix the current little bits and pieces you should be good to go
  5. #85
    Re: Lemon or not
    I would....car looks great to me and to a lot of othere here too.
    Amen to that.. father inlaw is a toyo man.
    I'm a nissan...
    My gq has racked up 497500k's.. had new injectors at 250 thou, water pump around then and New suspension about 10thou ago.
    His 80 series has just hit 200 thou (which I'm surprised at), he's changed
    Diffs, front and rear
    Clutch x3
    Cv's
    Steering pump
    Water pump
    Brake cylinders
    Uni's
    Hubs
    Bearings
    And that's the stuff I've helped him with in the last 5 years... :what:
    And to make things worse, his is a dual fuel 4.5ltr, and my ragged old td42 still keeps with him...
    You can't knock nissans... Well I can't..
    Owner of
    Westy's Accessories
    ckh
    Guest
    but the intermitent torque converter unlocking etc, and the fact i can get into diagnostic mode after the tranny guy changed the converter, its doing my head in.....
  7. #87
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    I'm a nissan...
    Clutch x3
    Cv's
    Steering pump
    Water pump
    Brake cylinders
    Uni's
    Hubs
    Bearings
    Owner of
    Westy's Accessories
    ......and spares are $$$$$ more than ours!
  8. #88
    Patrol Freak Parksy's Avatar
    Jan 2013
    Nowra NSW
    5 Post(s)
    Quote Originally Posted by ckh View Post
    You should buy a Camry. I'll have the patrol.
    Cheers.
  9. #89
    ckh
    Guest
    Quote Originally Posted by Parksy View Post
    Cheers.
    Have you got a decent one to swap?
  10. #90
    Mar 2013
    I think you need a new garage and mechanic more than a new vehicle!
