Results 11 to 20 of 24
Thread: Throttle position sensor anomally !!
    sunshinecoast
    I think my faults occurred the same way as yours coldcomfort , but i could not replicate it deliberately .
  2. #12
    Mine does it too. 2012 gu8. Very frustrating. Told Nissan about it, didn't get a Greta response. Service manager told me you do realize it has an electronic throttle.... Ah yes I do mate but what does that have to do with it... There is oviously a intermittent fault. Basically they tested it and said nothing wrong. Next morning sure enough did it agian.. Cannot replicate it no matter what I try.
    The list of mods is long, the funds are short!
  3. #13
    Jul 2012
    it could be unclean diesel, try other station next time you pump gas.
  4. #14
    Expert Steve4wdin's Avatar
    Feb 2012
    Western Sydney
    I seriously doubt fuel issues as it seems a lot of poeple have the exact same symptom. But I could be wrong.
  5. #15
    Legendary happygu's Avatar
    It isn't doing it just from cold with the Pre-Heat Switch engaged is it?
    Just thinking that it may be something computer related to the Pre-Heat Switching......
  6. #16
    sunshinecoast
    My car was always warm when it played up .
  7. #17
    SUCH IS LIFE Maxhead's Avatar
    ACT
    Quote Originally Posted by nipagu7 View Post
    I can't remember mine doing it when cold either
    ________________________
    ______ 2017 D-Max _______
  8. #18
    Well - we scratch that theory.......
    Mine has never had an issue, so I'm just trying to find some common ground....
    Mic
  9. #19
    Beginner Jim-m-72's Avatar
    brisbane south
    Mine will go at any time and won't go back to normal untill the motor is turned off for about 30 seconds and restarted the only way to get Nissan to see it was when I turned up, I called them let them know I was coming in arrived 10 mins before knock off and the tech was too busy to look and said come back later so I got a guy from behind the counter to try it then turned off the motor and started again then he said there was a problem so replaced the pedal assembly. We were trouble free for 6 weeks now its every 2 weeks it happens but they won't research to find the fault as no codes come up.
    Jim
  10. #20
    Expert Oldmate1's Avatar
    Mar 2013
    Brisbane. Wynnum West
    my gu9 2013 has just started to get the same problem it also starts to rev high about 2000 rpm at idle. its going to Nissan on Wednesday
    hopefully they find something not holding my breath though
