Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: GQ Recovery Loop/U
    Expert Bulbous's Avatar
    Apr 2011
    Dubai
    I wouldn't trust it for snatching, especially in something as clingy as mud. Replace it with a Pintle Hook
    Steve
    2011 Patrol Safari 4.8 (Fitek)
  2. #12
    Certainly wouldn't be using a pintle hook for snatching either. They are a rate TOW point much like a tow ball.
    BigRAWesty (15th February 2013)
  4. #13
    Patrol God Sir Roofy's Avatar
    TRAFALGAR VIC
    35 Post(s)
    Quote Originally Posted by koliilok View Post
    Hey, was having a discussion the other day with a friend about the loop thing on the rear of a GQ, is it a strong enough recovery point for snatching etc? I would assume it's bolted to the chassis but don't want to go tearing it off. I've always just fed the strap into the towbar and put the pin through previously.
    Corey
    if you keep up this practice you,l have many happy days
  5. #14
    Nov 2012
    This is what they look like behind the plate. Not impressed at all. And only a thin bead of weld on the out side.
    I wouldn't ever be snatching with this.
    Looks like i'll be leaving it well alone, that's not looking strong at all!
  6. #15
    Nov 2012
    Looks like i'll be either sticking to the strap in the towbar method or i might invest in an insert for it...or people could stop getting stuck and me having to pull them out? lol
  7. #16
    Hang around with patrol owners and you'll have no need for it.
    go buy a rated insert, not good when the pin bends, costs goes up
    Sad you only go driving with Yoto owners
  8. #17
    Nov 2012
    i believe they are only rated to 500kg
  9. #18
    I rate mine to suit the towing capacity of the 4x4, eg manual 3.5t
    This is done by a NATA accredited shop
