Results 1 to 8 of 8
Thread: Running a high draining 240 Volt Pure Sine Wave Inverter from the battery/alternator
Threaded View
  1. #2
    Nov 2010
    Assuming a good efficiency of about 90%, it will take about 90amps at 1000W and 180amps at 2000W peak. From this website http://www.powerstream.com/Wire_Size.htm it appears that AWG 2 would be the minimum gauge required. Over a 5m length, it will drop about 0.25v from the battery at 1000W, so nothing to worry about. Use a very good chassis earth (and check the battery is very well earthed) rather than a return cable, so you don't drop another 0.25v.
    1981 Nissan Patrol MQ SWB, 3.3TD, West Melbourne.
  2. The Following 2 Users Say Thank You to boggy2006 For This Useful Post:
    JungleJim (7th August 2011), mackayboi (21st January 2011)
