OK, so i have searched, it doesn't even tell me in my workshop manual. . . . . i need to know 2 simple things.
1: What is the fluid i am putting in my torque converter?
2: And how much?.
The converter is from a 2005 ZD30 patrol.
2: And how much?.
You could use the oil which is recommended for the 3.0 auto trans as it gets pumped from the tranny to the torque converter anyway.
Jacket_1985 (12th January 2013)
As long as there is something in it before initial start you should be right just re check your oil after it has run for a short period.
Assuming that there is no difference in the newer autos, from memory it 11.8L dry, ie torque converter and sump, and about 5-6L for a change. Im guessing your doing a service? If so out back in what you take out, then check the level and adjust as required. I use Castrol Transmax Z oil, expensive but good.
1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me)
ok, cheers guys.
